Is this modification to a chipper possible?
/ Is this modification to a chipper possible? #1
mpilihp
Jefferson, ME
Pasquali 988
Hello I have a DR 3PT chipper that has worked well for me on my 15hp Iseki tractor but I have upgraded to a larger tractor (Pasquali 988) and the PTO speed on it only goes to 750 where as the Iseki has a higher speed. Its too slow for us now, I tried a different chipper (Patu) but it unfortunately is set up more for chipping large trees (shoot down low) and is back breaking to put a lot of small branches in it.
So the DR has only one blade on the fly wheel, I am wondering if it would be possible to modify the flywheel to allow putting a second or even two more blades on the flywheel. This is beyond my ability but is this something a machine shop would be able to do?
Thanks
~ Phil
/ Is this modification to a chipper possible? #2
It sounds like more work than it is worth. If you do it, you should also make the flywheel much heavier too, to keep down drive-line shocks.
Hi well I was looking at this guy's posting on how he made his own chipper and appears pretty straight forward for someone who works with metal.
Steve Bedair's Wood Chipper
Use a torch to cut the slot, machine out a grove for the blade and drill and tap the mounting holes then balance it...
I can take it apart and resemble, I just cant do the modification to the flywheel.
~ Phil
/ Is this modification to a chipper possible? #4
Does anyone make an adapter for the PTO to increase the RPM's, like an overdrive unit?
/ Is this modification to a chipper possible? #5
a belt and pulley system would probably work better than gears in this application.
It should be easier to build than modifying the chipper I'd think.
/ Is this modification to a chipper possible? #6
I was under the impression DR chippers were designed for 540 pto speeds, perhaps I was wrong?
--->Paul
/ Is this modification to a chipper possible? #7
The newer DR I looked at was designed for 540rpm.
Well I dont have an engine Tach on either tractor so not sure what speed Im really running them at. I checked the manual on the Iseki and the 2nd PTO speed says its 752 and the Pasquali im running on teh 750 pto speed but obviously engine speed can make a difference. Either way on teh Pasquali it runs slower and is slower than death to chip, its like watching mushrooms grow. Im looking for a better alternative but not much for options around Maine and the second chipper I bought doesnt do what I want any better.
/ Is this modification to a chipper possible? #10
If you add anthing it has to be done so the unit as a whole / flywheel
remains balanced. I doubt just 2 will work, maybe 4, so as to keep it
balanced. I believe there are other considerations as well, as in to offset
blades or not to.
I think it might be best to put it up for sale and take your winnings
and ungrade to a new and improved unit.
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
PALLET OF (24) 2" X 8" X 27" CHANNEL IRON (A64280)
PALLET OF (24) 2"...
2005 Ford F-650 Rollback (A62613)
2005 Ford F-650...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
