is this mahindra a good deal its a 4110 with loader (pics) included.
   / is this mahindra a good deal its a 4110 with loader (pics) included. #1
moonmonkey
middleburg fl
l300f kubota
it has 1600 hours ..Manuel trans.. he wants $8500, it runs and works great he says, just has never seen the inside of a barn.forgot to ask year,they made this model from 2002-2009. no attachments rams just repacked,( it would replace my 1963 ford 4000 loader,its tired of me!)
   / is this mahindra a good deal its a 4110 with loader (pics) included. #2
IMHO it's rough. Paint fade doesn't bother me but the front grill is cracked along with the front headlight. Looks like it's had a hard life. I would be concerned about maintenance on the unit. If that could be verified you still have a geared tractor with a FEL. I would be looking for at least a shuttle shift or hydrostat.
   / is this mahindra a good deal its a 4110 with loader (pics) included. #3
Have you looked at it in person? What the engine warm or cold when you started it? a cold engine is going to show you a lot more issues then one that has bee running. Did you drive it around, lift a load of dirt with the loader and carry it around before dumping it? After driving it, did you check for leaks and inspect all of the hoses and look for a puddle under it while it was running and parked?
If its solid, that's a pretty good price for 41 hp and 4wd
   / is this mahindra a good deal its a 4110 with loader (pics) included. #4
It's a little beat up but as Eddie stated 41 hp for that amount is not bad.
   / is this mahindra a good deal its a 4110 with loader (pics) included. #5
I have an older 485. Great platform. I like the geared trans for the simplicity and ease of maintenance. One disadvantage is only 8 speed and slow shifting when doing loader work
8500 with loader is alright I would think if it is mechanically sound
   / is this mahindra a good deal its a 4110 with loader (pics) included. #6
Needs tires (also note fronts are reversed) plus other things mentioned. Tires and damage may be a bargaining tool if it runs well.
   / is this mahindra a good deal its a 4110 with loader (pics) included. #7
Not sure if it’s my old eyes or not but I do not see much grease around the pins.
drove the mahindra today, it is hard to get the shuttle shift to get into and stay in gear (will sometimes pop out and grind) and when raiseing the loader, it shudders so bad it it shakes the whole tractor (the salesman said it probably has air in the hydrolics because they just repacked all 4 cylinders,) plus while useing the clutch a screaching noise was coming from somewhere. ,, plus with the seat all the way back the pedals are waaaay to close and cramped. this thing must be for people 5,"6 or shorter, and he wont budge off of $8000, so im going to pass i think,thanks for all the help every
   / is this mahindra a good deal its a 4110 with loader (pics) included. #9
Good decision.
   / is this mahindra a good deal its a 4110 with loader (pics) included. #10
^^^^^ agree . . . and I find that most of the compact tractors out there, if your over 6' I have to do some reconstruction on the seat.
Tri-Axle Police Bunk Travel Trailer (A51694)
Tri-Axle Police...
2006 FORD F-250 (A52472)
2006 FORD F-250...
2022 New Holland T5.120 Tractor with Loader (A51573)
2022 New Holland...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
1263 (A50490)
1263 (A50490)
