Is this a stupid idea?
   / Is this a stupid idea? #21
loose the batterys, all that is a recipe for disaster. Go to your local tire dealership and ask for a bucket of old wheel weights, put them in feed bags then add as much or little to your box as needed
Depending on state most wheel weights are no longer lead they are coated steel, composite, and zinc weights. Some , but not all are stick on as the old style damages the newer aluminum rims. Along with the increased scrap prices you would be lucky to find anyplace giving lead weights away.
   / Is this a stupid idea? #22
zince melts too.. just takes a lil more than lead. :)
   / Is this a stupid idea? #23
You could also fill discarded one gallon antifreeze bottles with steel shot. I don't remember how heavy they where exactly, but I believe around 60 lbs. The handle on top of bottle makes getting them in and out fairly easy. The problem is finding someplace that handles steel shot.
   / Is this a stupid idea? #24
Take the batteries to the local scrap yard and swap it for odds and ends of whatever they have that's heavy.
You DON'T want to mess with batteries, and it appears that you've already come to that opinion.
   / Is this a stupid idea? #25
You can use anything that is heavy but when you start checking prices even scrap prices, you will find that concrete is cheapest for the per pound weight. You could just fill the BB with sand and cap with 3" of concrete to hold it all in.
   / Is this a stupid idea? #26
Does the sand provide enough weight for your needs? If so than stay with the sand but throw in a couple of 4" pvc pipes vertically in the box prior to filling it with sand. than the saw blade will fit right for the ride.
   / Is this a stupid idea? #27
when I made mine.. I found concrete and ballast mix to be the most economical way, even over scrap metal..e tc..
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2022 Chevrolet Express (A57148)
2022 Chevrolet...
2000 Ford F-450 Dump Truck, VIN # 1FDXW46F5YEB20130 (A57453)
2000 Ford F-450...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
