Is this a reciever of some sort
   / Is this a reciever of some sort #21
they make a 3 point setup that has a 2”receiver built in, you can make or convert attatchments, its slick, also works really good for trailors because you can raise or lower hitch, or a subsoiler for trenching, amazon has them.
   / Is this a reciever of some sort #22
I see the wholegoods price on a drawbar kit is only $60(50#) for a B26. Thunder Chicken’s receiver adapter looked useful too. Drawbar trailer hitch has some safety advantages over 3pt mounts.
There lots of safe ways and some not so safe ways to move a trailer with a tractor. Our manure spreader has to go on the drawbar. 3pt hitch it and your dead. Spreader tongue weight goes negative at the end of spreading a load a can lift, bend/break the 3pt hitch and crush the operator going down hill.
Anyway you choose use good sense, know your limits and consider how the forces effect the tractor.
   / Is this a reciever of some sort #23
Go with 3pt trailer mover. You can add a winch to pull stuff on trailer. You can easily mod concrete filled rollers for easy attachment.
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2018 Dodge Ram 5500 4x4 Crew Cab Flatbed Service Truck (A55973)
2018 Dodge Ram...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2015 Peterbilt 367 National Crane NBT55 110,000lb. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
