Is this a good chioce?
/ Is this a good chioce? #21
The 7.3L PSD is a good engine. 152,000 miles on that truck is usually nothing to worry about.
HOWEVER, if it has been a plow truck its whole life it will definitely be worth having the front end and frame checked out by a shop. Also, plowing is hard on transmissions (performance chips can be as well if the operator thinks a chip will make his truck a super-truck). If the tranny is bone stock you may be running into tranny problems with that truck, especially if it doesn't have a bigger tranny cooler and a tranny temp gauge. These two items are not guarantees, but would indicate that the owner was aware of and hopefully tried to stay away from burning up his tranny.
If you end up asking about that '99, be sure to ask about any front end and tranny work that has been done to that truck. Hopefully the owner kept receipts for any work so that you can confirm the work.
While the plow is not the V that you were looking for, Fisher makes a great plow and is one of the better ones out there (according to the plow sites that I visit). Still, check the plow to ensure good hydraulic response for all actions (angle left, angle right, lift, etc.). Also, check for any bends in the frame or signs of repairs.
No matter which plow you end up with, find you a plow site or two and you will find a fella by the name of Jerre. He can rebuild you a pump that you can be 100% sure about. If he is too far from you, he may know of a good rebuilder in your area.
HTH
The seller said the tranny was rebuilt at 125k. He also said it wasn't used to plow till around 100k. I didn't ask about the tranny cooler but it's not a huge deal to add a larger one. I believe those trucks were stock with the temp gauge. And info on a sander fitting in the rack body? That's a big issue for me. If I go with a rack body over a dump and I can't fit a sander I'll be quite upset. :mad:
Matt T.:D
/ Is this a good chioce? #24
Matt T.:D
Matt,
Heed your own advice and take a little of mine, too. Wait for a nice 1-ton 4x4 dump with a plow already installed, or maybe a dump stake body 4x4 with plow installed. The dual rear wheels bed gives you a wider platform for a bigger spreader and of course, more GVWR capacity.
Do it right the first time. I've bought too many trucks that were not quite right for the job.
This truck is really sweet for plowing, but not too good for summer work: eBay Motors: 99 F-450 4X4 (GOV'T SUPLUS)SNOW PLOW&SANDER DUMP!TRUCK! (item 330199583009 end time Dec-30-07 18:07:35 PST)
Here's some more examples: eBay Motors: 1999 FORD F 350 4X4 DUALLY DUMP DIESEL AUTO PLOW (item 110205001064 end time Jan-01-08 17:05:50 PST)
eBay Motors: 1995 Dodge Ram 3500 4x4 Mason Dump W/Plow (item 120200813046 end time Jan-10-08 11:07:27 PST)
eBay Motors: 2001 FORD F350XL DIESEL DUALLY 4WD SNOW REMOVAL DUMPER (item 250199595233 end time Dec-28-07 10:49:37 PST)
eBay Motors: 1997 CHEVY 3500 4X4 DIESEL DUMP UTILITY PLOW & SPREADER (item 350006409619 end time Jan-04-08 15:53:34 PST)
/ Is this a good chioce? #25
I was trying to read the picture of the yellow tag to see the tire size. It's not too clear but I think it reads 20" tires and seems to show a different size for front and rear.
The description of the truck says it's "low profile" and in the pictures the tires/wheels appear to be some type of low profile design. I would guess that low-pro tires would not be quite as good in snow as standard 20" or 22.5" but maybe someone else knows better about that. Possibly the wheels/tires were changed from original. What size tires are on the truck now?
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
John Deere S350 (A60462)
John Deere S350...
42" X 21' ADS DRAINAGE PIPE (A64281)
42" X 21' ADS...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2018 John Deere 50G (A64126)
2018 John Deere...
