Is this a 6 loop rim?
   / Is this a 6 loop rim? #1
spotco2
Ga
Ford 8N
My old 8N has larger than stock tires on the back. It currently has 12.4x28.
I was looking at Tucker Tire to order a new tire and tube already mounted to a 6 loop rim, but not sure it will fit.
Is this a 6 loop rim? It does not look like others I have seen pics of online.
   / Is this a 6 loop rim? #2
Not sure of your terminology but the rim shown has eight studs.
   / Is this a 6 loop rim? #3
Yes a 6 loop would be a replacement rim for the 24" 6 loop to be exact. What is pictured is an original rim from a 8N.
Cool! I thought these might be original (or at least period original) wheels from the 40's-50's. I did not notice the difference between these and the 6 loop rims until I started looking today and was not sure if a new one would fit the centers that I have.
Just found a local tire shop that would replace the tire and tube for $350, so I'll be keeping my originals!
Thanks.
   / Is this a 6 loop rim? #5
Yep that is a period original "hat" style rim.
If your rims are good though, no point in buying more. Cheaper to just replace tube and tire as you are doing.
   / Is this a 6 loop rim? #6
as said.. that is a hat rim. hat centers will bolt to 6 loop rims , if needed.
   / Is this a 6 loop rim? #7
lugnut studs has no bearing on the rim to center attachment. that is a hat rim.. a 28" 6 loop rim will mate to an original hat style center.
that's a 28"er
   / Is this a 6 loop rim? #8
I stand corrected 28" it is!
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
198367 (A51243)
198367 (A51243)
1 pallet of Tool box /Pump/5 safety cones (A53117)
1 pallet of Tool...
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
