Is this a 6 loop rim?
   / Is this a 6 loop rim? #1
spotco2
Ga
Ford 8N
My old 8N has larger than stock tires on the back. It currently has 12.4x28.
I was looking at Tucker Tire to order a new tire and tube already mounted to a 6 loop rim, but not sure it will fit.
Is this a 6 loop rim? It does not look like others I have seen pics of online.
   / Is this a 6 loop rim? #2
Not sure of your terminology but the rim shown has eight studs.
   / Is this a 6 loop rim? #3
Yes a 6 loop would be a replacement rim for the 24" 6 loop to be exact. What is pictured is an original rim from a 8N.
Cool! I thought these might be original (or at least period original) wheels from the 40's-50's. I did not notice the difference between these and the 6 loop rims until I started looking today and was not sure if a new one would fit the centers that I have.
Just found a local tire shop that would replace the tire and tube for $350, so I'll be keeping my originals!
Thanks.
   / Is this a 6 loop rim? #5
Yep that is a period original "hat" style rim.
If your rims are good though, no point in buying more. Cheaper to just replace tube and tire as you are doing.
   / Is this a 6 loop rim? #6
as said.. that is a hat rim. hat centers will bolt to 6 loop rims , if needed.
   / Is this a 6 loop rim? #7
lugnut studs has no bearing on the rim to center attachment. that is a hat rim.. a 28" 6 loop rim will mate to an original hat style center.
that's a 28"er
   / Is this a 6 loop rim? #8
I stand corrected 28" it is!
Ingersoll-Rand Winch (A53117)
Ingersoll-Rand...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2018 PRINOTH...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2015 MACK CXU613 (A53843)
2015 MACK CXU613...
2019 RBR Venturi 380 (A53473)
2019 RBR Venturi...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
