Box Scraper Is there really a difference in box blades?
   / Is there really a difference in box blades? #31
The key metric is weight per unit of width.
100 pounds per foot is OK. 125 pounds per foot is better. 150++ pounds per foot is nirvana.
Pictured Bush Hog (brand) 60" Rollover Box Blade weighs 630 pounds = 126 pounds per foot.
Soil: Florida sandy-loam.
I have the Frontier BB3272 6' Box blade on order. It is their construction grade and weighs 790 lbs
   / Is there really a difference in box blades? #32
Yep. One needs the weight. I have the 6' version of Jeff's and it weighs 700+ pounds. For my hard, rocky, clay soil I could really use something more like 1000 pounds. But 700+ works and just takes a bit longer time.
   / Is there really a difference in box blades? #33
Weight is everything with a blade. I added ~700 lbs to my 10' box blade that was already pretty heavy to begin with and it made a huge difference.
   / Is there really a difference in box blades? #34
This is why I ordered my 4066R with the down force kit that gives you 450 lbs of downforce
   / Is there really a difference in box blades? #35
As I recall the down force option eliminates too many other hydraulic options to make it reasonable. I don't think you will be able to do near as much with it as a tractor with proper ballasting and heavy implements. My 4520 has 1100 lbs of steel weights and WWF in the rear tires. The box blade pictured is 7' and 1260 lbs.
   / Is there really a difference in box blades? #36
Down force on the 3pt also means up force & corresponding loss of traction on your tires.
   / Is there really a difference in box blades? #37
It means I can drill a post hole in hard ground and can actually force my scarifiers into the ground. Having a heavy tractor does nothing for a implement like a blade or box scraper. You need the weight on the implement not the tractor axle.
Getting the down force kit kept me from getting the tilt/turn option which I don't need anyway as I have a dozer blade for my CTL
   / Is there really a difference in box blades? #38
My L3200 can barely pull my box blade full. I'm sure downpressure would reduce my traction enough so I could barely pull it empty.
   / Is there really a difference in box blades? #39
Notice the 3 pt arm hookup, normally goes along with a better quality than the single pin tab on other's, other's may disagree, my .02 cents.
Ronnie
   / Is there really a difference in box blades? #40
How much? Paying for shipping? Delivered to dealer?
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
