1st off, for those who might suggest getting a fel to add to your unit, it's very important you understand why a fel is expensive as an add-on. Remember that a tractor with no fel does not have the front valve which is much more than just a couple hydraulic lines. . . It's the valve and control arm and stanchions that the fel mounts to plus the hydro lines.
Now as for a "bare" tractor. . . . Units like that are desired for lawn care businesses or small towns who cut a great deal of parks. Also they use the 3 pt. For a 3 pt. Sprayer as well as seeders wood chippers, or post hole diggers or tillers or generators as well as flail cutters, bush hogs or finish mowers or pulling wagons or concrete mixers or a front or rear plowing blade or rear snowblower. I have a set of forks that I can use on my gel or on my 3pt.
My point would be . . . You are thinking a bare tractor is sooooo limited when a mid pto and rear pto give you many more options than a fel does.
