Is there an implement that will ?????
   / Is there an implement that will ????? #11
<font color="blue">...call that a "bedder"... </font>
Hi Bird,
You gots to remember I'm from New York... /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif
   / Is there an implement that will ????? #12
Now, Now John. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
MarkV
   / Is there an implement that will ????? #14
<font color="blue">...available with up to 15 inch sweep points ...</font>
Very nice Ken... /forums/images/graemlins/smile.gif
(What is the approximate replacement cost of the 15" shovels?)
Thank you all who have responded.
I guess I was not very clear regarding the results I'm looking for.
I would like to have one pass leave multiple furrows (trenches). In other words if the implement was 4 feet wide and spacing was 6 inches, I would have 9 furrors after each pass, or 7 if spacing was 8 inches.
Ken, what is the name of the implement you have pictured?
Thanks again to everyone that has answered and those yet to answer.
After the rain we just had, "it is too wet to plough".
   / Is there an implement that will ????? #16
The plow Ken showed is what my neighbor called a "chisel plow". He had a bigger, heavier one that was a pull behind (raise and lower hydraulically) instead of a 3-point; 2 inch wide chisel points spaced 12" apart and he used it in the pastures (including mine). It supposedly served the same purpose as aerators on your lawn, allowing air and moisture down into the ground.
   / Is there an implement that will ????? #17
Hi--The Mfgr calls it a "Field Cultivator" locals call them rippers or shank tillers--they dont go as deep as a chisel plow--These machines have variable spacing in width and 4 bolts removed will drop off a complete shank assembly--Used are usually available under $375 and new 9 shank models $675--Ken Sweet
Sweet Farm Equipment Co. * Disc Mowers Specialists*
   / Is there an implement that will ????? #18
Hi John--Most larger bedder/middle buster/ points available at most ag store outlets for under $25 and under $10 used at salvage yards--Ken Sweet
   / Is there an implement that will ????? #19
The field cultivator that Ken showed is what almost everyone uses in this area instead of a disc harrow. It does a much better job in heavy rocks than a disc. I orders a wide bedder point from my dealer not long ago and it was about $12.
   / Is there an implement that will ????? #20
Hello Jerry--This tool is also what most area tobacco growers use to work the soil, just before transplanting. Works the soil a lot deeper that a disc harrow and with less compaction, which is a killer for tobacco seedlings.--Ken Sweet
Sweet Farm Equipment Co. *Since 1977*
2007 Jeep Liberty SUV (A55853)
2007 Jeep Liberty...
CRATOS SHERPA 100 ECO ELECTRIC STAND ON SKID STEER (A57192)
CRATOS SHERPA 100...
flooring (A55758)
flooring (A55758)
White Metal Roof Panels (A55758)
White Metal Roof...
Rooster Weathervane (A55853)
Rooster...
2025 Swict 72in Bucket Skid Steer Attachment (A55851)
2025 Swict 72in...
