Is there a plumber in the house? (Stuck stopcock valve)
   / Is there a plumber in the house? (Stuck stopcock valve) #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Turned off both waterlines under the sink recently for a repair and now the hot side won't reopen. Put enough leverage on the handle to feel the shaft wind up a little and then relax when I let off of it. That shaft can't be that strong and might twist off. Suggestions welcome! (And I am turning it CCW)
   / Is there a plumber in the house? (Stuck stopcock valve) #2
Shut the water off at the meter and install a new stop is really all there is to do. They’re cheap and the installation is pretty easy.
Thanks for the quick response.
What hangs up inside the valve? Is it galling between two contact points? Changing it out will be like building a ship in a bottle while standing on my head!
   / Is there a plumber in the house? (Stuck stopcock valve) #4
First try turning it the other way not hard enough to twist the shaft, then try opening again.
   / Is there a plumber in the house? (Stuck stopcock valve) #5
This is why I HATE working on plumbing, and why I never turn the water off at the fixtures anymore. I just turn the water off at the main shutoff valve where it comes through the wall in the basement. Then, use the laundry sink in the basement to drain down the lines.
   / Is there a plumber in the house? (Stuck stopcock valve) #7
If it’s not a 1/2 turn stop you can pretty much count on it not working. Usually it’s oxidation preventing them from closing all the way. I’ve never experience one not opening back.
   / Is there a plumber in the house? (Stuck stopcock valve) #8
Me either, but it seems like mine start leaking about 80% of the time AFTER I open them back up. Opening them ALL the way seems to better the odds of them not leaking somewhat.
   / Is there a plumber in the house? (Stuck stopcock valve) #9
Worth a try to loosen the stem packing nut a bit and work the stem back and forth.
   / Is there a plumber in the house? (Stuck stopcock valve) #10
replace them all with 1/2 turn stops .. You'll thank me later
Only problem with that is, it involves doing plumbing work. Have I mentioned how much I really hate plumbing?
I know, I know, hire a plumber. No, I say, NEVER!! I refuse. I'm doing it myself!
2009 INTERNATIONAL CITY STAR REFRIGERATED BOX TRUCK (A56138)
2009 INTERNATIONAL...
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
2014 Jeep Compass 4x4 SUV (A55853)
2014 Jeep Compass...
2018 John Deere 1025R Tractor - 257 Hours (A55314)
2018 John Deere...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
