Is there a electrical outlet on L3130
   / Is there a electrical outlet on L3130 #1
marty236
I was wondering if there was a 12 volt outlet on a L3130 or if anyone has added one. Thanks
   / Is there a electrical outlet on L3130 #2
There's a wire under the seat that ends in a connector terminal, hot and ground. Turns off with the ignition switch, has it's own fuse.
   / Is there a electrical outlet on L3130 #3
It's the one with the green end. I ran my lights off of there..Hope this helps...
   / Is there a electrical outlet on L3130 #4
Is it me or your two pictures are "nearly the same"? ;)
   / Is there a electrical outlet on L3130 #5
Good Eyes. They were basically the same. I deleted one of them. :)
   / Is there a electrical outlet on L3130 #6
Man I love this site. I have seen that plug several times...never knew it was just a dead plug with hot and ground. Awesome, now I know where to hook up my ROPS lights (when I get some). I thought it was a diagnostic connection cannon plug or something like that.
COOL!!!
   / Is there a electrical outlet on L3130 #7
Is it the same on a B7800 ?
Thanks alot, I really appreciate it
   / Is there a electrical outlet on L3130 #9
JohnK
Did you cut off the green plug when you used the wire or did you find a matching connector?
NorthGA
   / Is there a electrical outlet on L3130 #10
I used the inline connectors with the metal plate you squeeze when you put the 2 wires in there. I forget what you call them . The new wire goes against the plastic butt end and the other wire goes in the groove parallel to it and you squeeze the metal tab that makes a connection between the 2 wires. Hope this helps.
New 20ft 5/16in G70 Tie Down Chain (A50323)
New 20ft 5/16in...
Magna Max Power Unit (A50121)
Magna Max Power...
2017 Ford Expedition SUV (A50324)
2017 Ford...
2023 Kubota L2501D 25HP 4WD Front Loader Utility Tractor (A50322)
2023 Kubota L2501D...
44509 (A51692)
44509 (A51692)
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
