Is there a electrical outlet on L3130
   / Is there a electrical outlet on L3130 #11
johnk said:
I used the inline connectors with the metal plate you squeeze when you put the 2 wires in there. I forget what you call them . The new wire goes against the plastic butt end and the other wire goes in the groove parallel to it and you squeeze the metal tab that makes a connection between the 2 wires. Hope this helps.
It's called a "splicer".
   / Is there a electrical outlet on L3130 #12
Podunkadunk said:
Man I love this site. I have seen that plug several times...never knew it was just a dead plug with hot and ground. Awesome, now I know where to hook up my ROPS lights (when I get some). I thought it was a diagnostic connection cannon plug or something like that.
COOL!!!
I have a hot and ground somewhat like that on my New Holland. I have to be careful though as when I added ROPS lights that when I start with the glow plugs I can't have the lights on or I will trip the main fuse. You may want to check that out. You end up tripping when you least expect it.
murph
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
