Is there a dif between 2022,2023 and 2024 T474?
   / Is there a dif between 2022,2023 and 2024 T474? #1
tjklein
NJ
none
Hi- looking at a new tractor to mow around 15 or so acres of field- some hills- My local dealer has a new 2022 474 hydro/Loader that I can get for around $23,000 with 3.9% financing-Is that a good price and are there any dif. between the years as he also has a 2023 and a 2024 for about a $1,000 more per year- Does it matter??-Also it shows that this tractor is only 54.5 inches wide- which seems narrow compared to others I have looked at- Will this be a problem when mowing on inclines due to the short width or am I reading this wrong as a newbee- thks so much
   / Is there a dif between 2022,2023 and 2024 T474? #2
On my Branson/TYM the rims can be adjusted to add width... Is that the same in the 474?
   / Is there a dif between 2022,2023 and 2024 T474? #3
I have the 2022 T474 cab version. Bought it new from the dealer. I haven't found anything different when comparing to 2023/4 versions besides some styling. Regarding the width/stability, yes it's narrow but you get used to it. I have the rear tires filled so that helps and a heavy implement on the back helps as well. You can buy rear wheel spacers also.
   / Is there a dif between 2022,2023 and 2024 T474? #4
I have a 2019, it didn't come with extendable 3 point lower arms was all that differs from current models, and park lights are oval and orange versus square and white/orange. I have R4 tires and mine was 64'' wide factory. I've now added 1.5'' wheels spacers to add 3'' total width to mine.
   / Is there a dif between 2022,2023 and 2024 T474? #5
If you are worried about stability, you could step up to the 494. Wider and heavier.
   / Is there a dif between 2022,2023 and 2024 T474? #6
Has the dealer provided any insight as to why the 2023 and 2024 models cost more? Are there features or optional packages included with those models that the 2022 doesn’t have?
Geometry Dash
   / Is there a dif between 2022,2023 and 2024 T474? #7
Probably just inflation
   / Is there a dif between 2022,2023 and 2024 T474? #8
Just get the 2022 one, I don't have extender 3 point arms. Mine did come with a rear window wiper. Mine is a 2019 early production.
48" Pallet Forks (A59814)
48" Pallet Forks...
Tractor (A59228)
Tractor (A59228)
John Deere 1025R (A53317)
John Deere 1025R...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
