is there a big difference in 6 HP ?
   / is there a big difference in 6 HP ? #1
Ankenyike
Ames iowa
Deere 3038E
I have a 3038E compact tractor, a 3 cylinder, 37.3 HP, 91 CID engine, 2,200 # weight and need a bigger tractor. Looking at a 4044R which is only 6 hp more - 43 Hp, but has 4 cylinders, and 133 CID, and weighs 3,770#. I am being told this will have more actual power than the 6 HP increase would indicate. Will be used mainly for hauling dirt & gravel in the bucket, some digging and leveling of ground. What do you think? I can go up another 8 hp with turbo for $3,000 more, but will I need that?
   / is there a big difference in 6 HP ? #2
generally I'd want to take a more meaningful step for your out of pocket money. Something with more meat in the rear end. in my world, Kubota MX.
   / is there a big difference in 6 HP ? #3
6HP is 6HP regardless of what anyone claims. Regardless of cylinders, Turbo vs NA, etc.
What is more important is you are gaining weight which is traction. And since its a larger frame, probably larger tires too. Again, more traction.
So, when you say you need more power, do you actually need more power? Or do you need to get more of it to the ground (traction).
If you were running primarily PTO stuff, like a mower or tiller, then you would not notice as much vs needing the power to the ground.
IE: 40hp and 4000lbs will push/pull more than 40HP and 2500lbs. But wouldnt make any noticeable difference when driving stuff from the PTO
   / is there a big difference in 6 HP ? #4
If your primary uses are moving dirt, digging, leveling ground, etc....why buy a tractor in the first place? My LS was over 5,000lbs with the loader and bucket, then I added a 1,400lb counterweight, and a tooth bar to the bucket. It would dig dirt, and lift/move it, but it was obvious that wasn't what it's designed for.
   / is there a big difference in 6 HP ? #5
Regardless of which tractor color you choose, I'd opt for the most HP available in the frame size you want, and can afford. $3000 for an additional 8HP ain't bad in the long run, especially when the day comes that you need it. If I could add 8HP to mine for $3k, I would.
But, for the work you are talking about doing, keep in mind that JD loaders (400x) are on the weak side compared to the rest of the large CUT industry. I think only the Case/NH comparable loaders are weaker. Just food for thought.
   / is there a big difference in 6 HP ? #6
I went from a Kubota B3300 (1929 pounds / 33-hp) to a Kubota L3560 (3494 pounds / 37-hp).
Yes, the heavier L3560 is noticeably more "powerful" than the lighter B3300, more than the additional 4-hp.
1. more weight
2. wider, taller tires, better traction (I had/have R4s on both tractors)
3. wider space between wheels
4. much more stable due to #1 + #2 + #3
5. heavier engine and heavier engine flywheel driving PTO
For DIGGING get a Piranha Tooth Bar for the bucket.
How frequently do you mount implements on the Three Point Hitch of your current tractor?
Have you considered a Utility Vehicle and all terrain dumping trailer as partners for your current tractor, rather than trading in?
TRAILER LINK: MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler - Welcome
   / is there a big difference in 6 HP ? #7
Horsepower vs weight, to extremes:
Bruce
   / is there a big difference in 6 HP ? #8
There is a lot more than horsepower vs weight going on there. One, the drawbar isn't level, which hurts the Deere significantly. Two, a steam engine can create boatloads of torque at zero RPM, which is a huge advantage. On top of all that, the steamer weighs a lot more....it's pretty much a stacked deck in every way.
   / is there a big difference in 6 HP ? #9
This is also the main argument for Hydraustatic (HST) transmissions: Max torque at load engagement, when you need it most.
   / is there a big difference in 6 HP ? #10
put that green thing in 4WD!! but likely it still would lose!
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
