Is there a better way to refuel the TC series tractors?
   / Is there a better way to refuel the TC series tractors? #1
nickel plate
CA
2002 New Holland TC40S
Maybe it's just me but refueling my 2002 TC40 is just a real PITA! With the filler neck 54" off the ground, climbing up on whichever implement is currently attached and jockeying around with a five gallon can of diesel is no walk in the park. I use the tractor primarily for mowing, splitting firewood and hauling tree trimmings to the burn pile-all this is seasonal work so thank God I don't have to "fill 'er up" often. Tried a ladder but no dice. Now I just partially fill the can(s) to decrease the weight and initial pour angle.
So basically I've just grumbled to myself through the refueling process until a friend recently bought a new Branson tractor with the fuel tank filler neck placed at the same height of the work deck! Makes that job as easy as refueling a riding mower...
Anyone have a better solution as in a nonelectrical pump or? I don't want to detach the implement and trying to keep the spillage/messiness factor to a minimum.
   / Is there a better way to refuel the TC series tractors? #2
This really works great for me, cost me under 250 including a 10mic filter I cobbled on it holds 35 gallons painted it yellow with leftover CAT rattlecan. SO Much better than lifting cans and using funnels. No more spilling and getting a workout before actual work. I also add a little biocide every time I fill it.
   / Is there a better way to refuel the TC series tractors? #3
12V submersible diesel fuel/water pump with leads clipped on to your tractor battery.
1-1/2" dia. pump drops inside the 5 gal can fill spout.
Can sits on bldg. floor.
Will pump 5 gal. can dry in under 2 min.
$21.99 on E-Bay.
   / Is there a better way to refuel the TC series tractors? #4
Not cheap, but this is what i use. It’s plastic so no rust. Pumps 10 GPM. HOLDS 55 gallons of diesel.
Enduroplas. Sold thru northern tools, other places
   / Is there a better way to refuel the TC series tractors? #5
Looks nice, but for less than ten 5 gal. (yellow plastic) containers each season for me, the $22.99 E-Bay 12v submersible pump is absolutely perfect.
   / Is there a better way to refuel the TC series tractors? #7
Well, ya get what you pay for. I go thru a lot of fuel usually, though not this year. No snow To speak of.
   / Is there a better way to refuel the TC series tractors? #8
While a pump is much better, this is one time I like the new fuel cans with the spring loaded nozzle valves. The hook rests on the filler lip so I dont have to hold it. Still gotta get it up there first though..
494ee98c-195c-4b25-8b8d-dbefb0c3a929
   / Is there a better way to refuel the TC series tractors? #9
I just set a 5 gal jug on top of the loader arm and use a shaker type siphon hose. Same method I use for my jeeps when I'm off road. Simple low tech solution.
   / Is there a better way to refuel the TC series tractors? #10
this is what i use, expensive, but once you lift it, you don't hold anything other then the fill lever, mine is on the hood. terrible design as well on mine
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
2012 Jaguar XJ Sedan (A55758)
2012 Jaguar XJ...
2002 GMC Stake Body Dump (A47477)
2002 GMC Stake...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
UNUSED Mini Excavator Grapple Attachment (A47477)
UNUSED Mini...
2012 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A55745)
2012...
