Is the Cyber Truck a Flop?
/ Is the Cyber Truck a Flop? #701
He has now put 10,000 Starlink satellites in space and successfully launched 132 rockets this year.
And now they are falling from the sky.....1-2 a day.....going up to 5 a day. :eek:
Here’s what you’ll learn when you read this story:
  • Starlink satellites in low-Earth orbit are de-orbiting and falling to Earth at the rate of one to two per day.
  • If Starlink continues scaling up operations, there could be as many as five of these satellites raining down on us daily.
  • Debris from rockets and satellites contains metal particles that could deplete the ozone layer.
SpaceX’s Satellites Are Falling From the Sky Every Single Day
/ Is the Cyber Truck a Flop? #702
....hundreds of them. :rolleyes: Real sales of the CT has flat-lined.........🤡:ROFLMAO:
I can understand not wanting to buy one yourself, but why do you derive such joy from the failure of an American automaker’s product ?
Maybe you’d prefer Chinese companies to take over, because of your personal biases against…?
/ Is the Cyber Truck a Flop? #703
It's not really being truthful about sales numbers when the CEO is buying hundreds of them, is it? It seems to me that the numbers are a bit skewed.... :rolleyes: Shouldn't we want more transparency on real numbers, not manipulated ones? Stockholders should..............
/ Is the Cyber Truck a Flop? #704
Yeah, nice try at scaremongering.... Low orbit satellites are designed to burn up on re-entry when they run out of fuel and are decommissioned. Would you prefer they do what DirecTV does with theirs, and put them into a "graveyard orbit" where they run the risk of causing damage?
Tesla doesn't break out other fleet or government sales separately already, so if SpaceX or Twitter/X obtain the vehicles at fleet pricing, it's really no different than Hertz, Avis, Budget, and Enterprise buying Model Y's or 3's as rental cars.
If anything, having these go to xAI, Twitter/X, and SpaceX shows that they eat their own dog food as far as a commitment to climate and electric fleet vehicles.
/ Is the Cyber Truck a Flop? #707
One apparently struck you on the gourd.
Simple minded people like you always resort to personal attacks on TBN members.....yawn. 🤡
adjective: simple-minded
  1. having very little intelligence or judgment.
/ Is the Cyber Truck a Flop? #708
Yeah, what could possibly happen with all those satellites raining debris down on us.
Maybe this:
MSN
This could have been a lot worse if it had breached the cockpit window, a lot worse.
/ Is the Cyber Truck a Flop? #709
Maybe this:
MSN
Ouch.....yeah, that is not good.
/ Is the Cyber Truck a Flop? #710
R. G. Letourneau wrote in his autobiography that electric motors are so much more powerful than gas or diesel engines that they didn't need transmissions. He built his mining equipment with one on each tire.
Most rely on motor types that can produce maximum torque over most or all of their lower RPM range, such that no transmission is needed. We need transmissions on gasoline engines to keep them operating in a much more limited range of RPM (e.g. 2000 - 6000 RPM under load), but most EV's today are running motors that can run from full-stop up to more than 20,000 RPM, and produce maximum torque over the lower half of that range.
I don't know if Tesla has a transmission, but I find it interesting how much power electric motors have.
No transmission in any of those I know, but I'm no Tesla expert. Electric motors actually fall short of gasoline engines on maximum power (torque * RPM), but they have gobs of torque.
/ Is the Cyber Truck a Flop? #711
Until then, I'm going to ride this wave. $14 bucks for a fillup. $80 less per month for insurance. $0 in maintenance. 775 lb/ft of torque in a 1/2 ton truck. It's actually really really nice.
So those don’t need brake pads or anything?
It's more about a prediction coming true than taking joy in an American automaker's failure. It's a "told ya so" moment.
/ Is the Cyber Truck a Flop? #714
Brakes last a long time of the vehicle uses regenerative braking.
Interesting aspect of electric vehicle braking: My front wheel drive hybrid lightly applies the rear brakes (for stability) when it's regenerative braking. As a result, driven conservatively, the front brakes essentially never wear out but the rear ones do - the opposite of a conventional car.
/ Is the Cyber Truck a Flop? #715
Tesla is doing quite well, regardless of the CT sales numbers.
Yep, the stock price is doing well too. Tesla P/E is incredible @ almost 250!!! Compare that to Ford at 16, GM at 9.5. Heck Nvidia is only 51!
Having said that, CT is still a big belly flop! :LOL: Which is what this thread is all about. ;)
/ Is the Cyber Truck a Flop? #717
Perhaps, but those are laminated windows intended to survive quite a bit of impact
More details have come out, though, and it likely wasn't "space debris" but a weather balloon. At cruise, you're traveling maybe 1 mile every 7-8 seconds. Something that size probably wouldn't be visible until seconds before impact.
One leading theory is that the aircraft collided with a high-altitude weather balloon. WindBorne Systems, a company that operates long-duration research balloons, confirmed that one of its devices may have struck the jet and said it is cooperating fully with investigators.
The airplane later flew under its own power to a repair site in Illinois.
/ Is the Cyber Truck a Flop? #718
There IS a coolant system. It uses the same coolant a gas model uses. The coolant is for the purpose of controlling battery pack temperatures. So I suppose that at 150k miles that will need to be flushed and refilled.
There is brake fluid, of course. I never change brake fluid as a maintenance item. Haven’t in the 30 years I’ve been driving. But I know some people do.
Eventually the brake pads will wear out, but guys with 150k miles or more on these trucks say the pads last a LONG long time due to the regenerative braking system.
I believe that some guys change the gear oil in the electric motors at high mileage too.
But as far as engine oil, oil filters, trans fluid, t-case fluid, grease fittings, etc. etc…. nope there’s none of that.
/ Is the Cyber Truck a Flop? #720
Lol.. couldn’t have said it better, myself!
Anyone who thinks Tesla’s aren’t selling due to poor performance has their head in the sand. Ugly, yes. Too expensive, yes. Range limited, on the scale of a Wyoming driver, yes. But most of the other arguments I hear against them just sound like people grabbing at straws, trying to justify an unwarranted bias.
I'm far from a T fanboy but I have to say that T completely rewrote the concept of the performance car - before them, a sub-6-second 0-60 was pretty impressive, and sub-5 was generally motorcycle territory (or 911 turbo, etc).
T comes along and everyone with a right foot can completely destroy the local mustang kid, and now everyone and their mum has a sub-6-second car.
The funny thing is, they pushed the standards of performance so far that it's pretty easy for pretty much any car maker to make a too-quick "good enough" car, and even the slower EVs are still quick enough for anything other than the most clueless driver (ok so not quick enough hahaha) on the road.
Utility Cart (A59231)
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A60430)
UNUSED SDLANCH...
2017 TERRAMAC RT14 CRAWLER DUMPER (A60429)
2017 TERRAMAC RT14...
2018 CATERPILLAR 305E2CR EXCAVATOR (A60429)
2018 CATERPILLAR...
