Is the BX25 large enough?
   / Is the BX25 large enough? #21
Yeah, u know when you kinda have a gut feeling about something, but your brain and common sense tells better, thats the way Ive thought about the BX!
Yeah, it goes both ways though. I had convinced myself one time that a B was the ideal tractor for me. I researched them for months during the winter months and after crawling all over them, I learned the BX was the right one for me.
I do, however have other tractors and if I hadn't, I would have gone with the B.
   / Is the BX25 large enough? #22
Should have no problem reaching over the sides of the dump trailer.
1*I've used my 2350 to load a one ton dump truck.
As for the hoe, the bota will out dig that case any day!!!! Jk
1*I've been thinking about getting a 1 ton dump truck
but was concerned about being able load it with my BX23.
TripleR, Thats something to think about also, since I have access to larger tractors, I thought the BX would be good to have around for the smaller jobs you cant do with larger equipment. Digging water lines around houses, working a garden, four wheeler trail maintence,well you get the picture, it goes on an on! Lutt
That was one of my concerns with the dump trailer. When I get home, I am gonna have to put a tape on it. But I think the farms dump trailer will be roughly 4' tall over the side. That would be from the ground to top of the side. I belive it has 3' sides. Lutt
   / Is the BX25 large enough? #25
TripleR, Thats something to think about also, since I have access to larger tractors, I thought the BX would be good to have around for the smaller jobs you cant do with larger equipment. Digging water lines around houses, working a garden, four wheeler trail maintenance,well you get the picture, it goes on an on! Lutt
That is why I bought a second BX as it is a very capable machine in a small package. If I need more capability, I grab a different tractor.
   / Is the BX25 large enough? #26
I honestly think we all need at least 3 tractors around.
It's the Goldilocks syndrome.
OK, not going to happen, thus I have a B. :D
   / Is the BX25 large enough? #27
I have a BX23 and a 1-ton Ford F350 dump truck. The BX will just barely lift the FEL high enough to clear the sides with the wooden extensions removed. It will do it, but you have to be on level ground and careful. That said, I can get 8 or 10 buckets per truckload, which is real nice for doing driveway work.
To the OP - I have 13 acres and would like a slightly larger tractor. If your Case is available most of the time maybe the BX would be fine but I'd certainly test a few out to make sure it's the right fit for your needs.
   / Is the BX25 large enough? #29
I've got my 3 so I must be done.
I was thinking of going with a flat bed with removable sides.
Do you think that would help with the clearance?
   / Is the BX25 large enough? #30
Ah, but all of our tractors are "just right".
We have tried the one tractor route more than once and it doesn't work for us. You are a lucky man indeed.
OK, OK, we might be able to do without one of our tractors, well maybe two, but that's it; I'm pretty sure anyway...:eek::(:confused:
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
Case IH 1063 Corn Head (A50514)
Case IH 1063 Corn...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
66" Skidloader Tooth Bucket (A50774)
66" Skidloader...
2020 CATERPILLAR 242D3 WHEELED SKID STEER (A51242)
2020 CATERPILLAR...
