is the b7610 the same as the b2400?
   / is the b7610 the same as the b2400? #1
Unregistered2013
i am looking at a b7610 and am wondering if the frame, etc. will take my b2400 stuff, like the blower/plow subframe, etc.
thanks!
eric
   / is the b7610 the same as the b2400? #2
I'm thinking that they share the same basic chassis. Major difference was in the position control on 2400 vs 1/4 inching valve on 7610.
   / is the b7610 the same as the b2400? #3
As B2400 stated, they are largely the same. When I had my B2400, and was looking for a loader, they were the same between a 7610 and my B2400. Also, when i was looking for the subframe kit to mount my Woods hoe on the B2400....... Woods didn't list one for the B2400. I call to Woods' tech support by my local dealer got the answer that the subframe kit was the same for both tractors....... it was a slight brain fart on the part of Woods not to include the 2400 along with the rest of the Bs (2410, 7500, 7610 etc.) that the same subframe fit. I would fall over backward if your snowblower is not a direct bolt-on also. You will be losing the position control though...... if it matters to you.
   / is the b7610 the same as the b2400? #5
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2020 JOHN DEERE 332G (A50854)
2020 JOHN DEERE...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
