is the b7610 the same as the b2400?
   / is the b7610 the same as the b2400? #1
Unregistered2013
Gold Member
i am looking at a b7610 and am wondering if the frame, etc. will take my b2400 stuff, like the blower/plow subframe, etc.
thanks!
eric
   / is the b7610 the same as the b2400? #2
I'm thinking that they share the same basic chassis. Major difference was in the position control on 2400 vs 1/4 inching valve on 7610.
   / is the b7610 the same as the b2400? #3
As B2400 stated, they are largely the same. When I had my B2400, and was looking for a loader, they were the same between a 7610 and my B2400. Also, when i was looking for the subframe kit to mount my Woods hoe on the B2400....... Woods didn't list one for the B2400. I call to Woods' tech support by my local dealer got the answer that the subframe kit was the same for both tractors....... it was a slight brain fart on the part of Woods not to include the 2400 along with the rest of the Bs (2410, 7500, 7610 etc.) that the same subframe fit. I would fall over backward if your snowblower is not a direct bolt-on also. You will be losing the position control though...... if it matters to you.
   / is the b7610 the same as the b2400? #5
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A52128)
2018 Dodge Ram...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
19008 (A48082)
19008 (A48082)
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
