is the b7610 the same as the b2400?
   / is the b7610 the same as the b2400? #1
Unregistered2013
i am looking at a b7610 and am wondering if the frame, etc. will take my b2400 stuff, like the blower/plow subframe, etc.
thanks!
eric
   / is the b7610 the same as the b2400? #2
I'm thinking that they share the same basic chassis. Major difference was in the position control on 2400 vs 1/4 inching valve on 7610.
   / is the b7610 the same as the b2400? #3
As B2400 stated, they are largely the same. When I had my B2400, and was looking for a loader, they were the same between a 7610 and my B2400. Also, when i was looking for the subframe kit to mount my Woods hoe on the B2400....... Woods didn't list one for the B2400. I call to Woods' tech support by my local dealer got the answer that the subframe kit was the same for both tractors....... it was a slight brain fart on the part of Woods not to include the 2400 along with the rest of the Bs (2410, 7500, 7610 etc.) that the same subframe fit. I would fall over backward if your snowblower is not a direct bolt-on also. You will be losing the position control though...... if it matters to you.
   / is the b7610 the same as the b2400? #5
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2012 LINDE H80D FORKLIFT (A50854)
2012 LINDE H80D...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
Adams Conveyor (A51039)
Adams Conveyor...
