With that little hours on it the clutch plate for the pto is probably siezed to the flywheel. Seen it alot in tractors that don't get used alot. You could try a rotary cutter and rev the throttle up and down quickly while holding the clutch pedal all the way down at the same time. This may jar it loose. If not you may end up splitting the tractor to get it unstuck.
