Is NH 7740 incompatible w/ JD HX15 batwing?
   / Is NH 7740 incompatible w/ JD HX15 batwing? #1
Meadowlight
NH7740
Hi. My NH7740 continually snaps off its PTO shaft pulling the JD HX15 batwing.
   / Is NH 7740 incompatible w/ JD HX15 batwing? #2
I suspect your batwing probably has a drive shaft with a CV joint that's out of balance.
   / Is NH 7740 incompatible w/ JD HX15 batwing? #3
:welcome:
Welcome to the forum!
:tractor: I'm going to move this thread over to our New Holland section.
WOW! JD repaired the drive shaft and the collar (is that the CV joint?). The replacement half of the shaft was too big to slide in the original outer half. This is over my head. What specifically should I ask them to do?
I don’t know. Local John Deere repaired it, and they are under new management. Should I ask them?
   / Is NH 7740 incompatible w/ JD HX15 batwing? #7
Is the PTO shaft the right length? If the shaft bottoms out going through a dip, I've seen it break the PTO shaft on the tractor.
I barely started the thing. It was on a level road. Edged over to mow parkway beside (and level with) the road. PTO shaft was level from tractor to implement. When I got out to see why the pto was on but it was not cutting grass, I saw the PTO stub had shorn off at the tractor ��. We had only traveled 40’.
The yoke is missing 2 snap rings - though the pin does not appear to have slipped any. Could this have caused it?
Hey Showcattle,
Done that too - bottomed out going through a dip. Later learned you’re only supposed operate in float position.
UNUSED FUTURE 24" HYD MINI TILTING BUCKET (A58376)
UNUSED FUTURE 24"...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A58375)
UNUSED SET OF...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2015 Bad Boy 72in Zero Turn Commercial Mower (A56857)
2015 Bad Boy 72in...
UNUSED JCT HYD AUGER 8", 12" & 16" BITS (A58376)
UNUSED JCT HYD...
