LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,221
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I would consider that to be the minimum acceptable battery that would likely work when everything is at 100%. Add in cold weather, wear and tear and then you end up with poor or not starting.It's a battery to start your tractor and provide 12V during runtime. Pretty sure the battery size/type spec'd by the manufacturer is 100% adequate. Why one would want to find a physically larger battery and deviate from that is curious. Obviously getting one with higher CCA is good if you live in a cold climate, but beyond that I see no reason not to use the stock spec battery. Have you added extra accessories that draw a lot of power like a ton of lighting or a winch?
Just as I consider most "code" and other specs to be minimums and I prefer to go past minimums.
