Is my loader is piece of crap?
   / Is my loader is piece of crap? #1
Tractor Beam
I have a john deere 990 with a 430 loader. I noticed that all the pivot points are not insert bushed. I am aware that the pins are likely softer in material than the initial bushings themselves, but was surprised to see that the bushings were not replaceable. Is this typical?
Everyones out checking their loaders right now I bet! :laughing: Just was curious, because it it is the norm, I'm trading it for a Kubota!:D
   / Is my loader is piece of crap? #3
Would the JD be second hand or has been rebuilt?
   / Is my loader is piece of crap? #4
My Caterpillar D4 and JD backhoe do not have separate bushes and they seem to work fine.
I assume my 430 will, too.
Good luck with your trade.
   / Is my loader is piece of crap? #5
This is a CUT, not a tractor marketed towards heavy construction or commercial use-that's what skid steers are for. If you keep all the pivots well greased your loader will outlive you. There are no threads here about 430 (or any other) loaders falling apart because of non-replaceable bushings.
   / Is my loader is piece of crap? #6
Tractor Beam,
Kenny usually has some of the the best technical answers around here. I was curious on this answer and was gonna suggest just naming the post "KennyD".
It'd be like fishing. You'd wait for him to take the bait....then get your answer.
Thanks Kenny,
   / Is my loader is piece of crap? #7
Absolutely not a piece of crap. I've a JD 430 loader, and used it a lot. No sign of a problem.
Not sure what the OP is all excited about.
And I didn't go check them. :D
Didn't need to, because it is still tight, and I keep them lightly greased.
Have fun with your other brand. We'll look in on your posts there. :)
And play the Music soft and slow. :)
   / Is my loader is piece of crap? #8
Come on folks... the guy asked an honest question!
No need to turn on 'em like you're behind on your rabies vaccinations! :D
FWIW - the bucket pins on my old JD 80 FEL were gettin' pretty sloppy. I was planning to take it to a local machinist and have oversized bushings installed.
Cheaper than a new loader... likely about the same total cost as a good used bucket - IMO.
'Course the new 300CX has replaceable bushings - he could always go that route - and get more lift capacity in the bargain! :thumbsup:
AKfish
   / Is my loader is piece of crap? #9
Yep, 300CX here!
   / Is my loader is piece of crap? #10
Might we be seeing a 990 going up for sale in the near future for cheap ?
Where do you live Beamer ?
(I've got the upgrade bug)
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A55301)
FIRESTONE 9.5L-15...
