bradc
I recently traded my 1 year old 4110 for a new 4210 e hydro. I have a very long driveway and wanted the big snow blower so it was new tractor time!! I am generally very happy , this tractor is great. The problem (or non problem?) I have is it seems to be down on power. It runs smooth , idles with no smoke etc. but here is the problem. I went to drive down the street to my neighbors to help him backblade some stone in his driveway and when I put in it high (C) range , the tractor will not pull the gear. This was driving with no pto implements and just with my 4 foot back blade hanging off the back on flat paved road. If you throttle up to operating rpm (2600) and accelerate slowly with the hydro pedal when you get about halfway down on the pdal the tractor runs out of power and you need to back off the pedal. I initially thought maybe the gearing is just way high and it won't pull that gear. But the more I drove it the more it seemed to not have any guts. Can any other 4210 owner comment on this, will your tractor pull top gear? I am not looking to race around (haha) but with out any attachments on pavement in 2wd I though it would pull high range. It will come close to stalling if you leave your foot depressed , you have to back off or it will die. B and A are fine. The dealer made a servoice call this week , they suspected the brake rods were dragging. I had verified the weren't by jacking previously but they were certain that was the problem. After inspection they found tha brake rods were fin and not dragging and after driving the tractor the technician agreed it "seemed" down on power. but all his tests showed it was running fine. I should note the tractor has only 6.5 hours on it and it could still be tight and not generating full power. It is also on the same tank of diesel that it came with so maybe I have old fuel with low Cetane rating... any comments would be great. My dealer is sold out of 4210's or I would have driven another one to see if its normal or not.
Thanks!
Brad
Thanks!
Brad
