The idea that repairing modern cars is too complicated, and requires a dealer, mostly isn't true.
Unless you drive a high end late model car, which is going to be under warranty, most things can be done without involving the dealer. I have seen BMW's that required the dealer to reset the computer, after ridiculous things like valve cover gasket replacement, and battery replacement go through the shop. (Caveat emptor).
Yes, it's probably going to require more steps to do a repair, but the level of intimidation depends on your level of experience. Most of the time, it's not as bad as it looks.
Diagnosing has gotten easier, since a modern car will often tell you exactly what's wrong.
We now have more complicated tools now too. You can fix almost anything if you have the internet.
I don't care for things like having to pull an intake manifold to replace spark plugs, but they also don't have plug wires to replace, and last for 100k miles.
Electrical problems are more common now, due to the miles of wires all the computerization uses. But, those issues are often common, and in that case, the internet can get you to the problem.
