Is it worth it or not?
   / Is it worth it or not? #1
JD230511
Indiana
John Deere 2320
I have a John Deere 2305. i was wondering if the independent lift kit is worth it or not. I would like the 3PH and mower deck to work seperate from each other. So my question is, if the independent lift kit worth it? thanks for the help.
   / Is it worth it or not? #2
It was to me. Just sold my 2305 this spring and bought a 2520, without the mower deck. I had the independent lift kit on the 2305, I didn't like the fact that my quick hitch was down when mowing, or the deck down when using the 3 point hitch. I had that kit installed after only mowing a couple of times. Kinda pricey but was worth it to me.
   / Is it worth it or not? #4
Learn how it works to avoid disappointment. A lot of people expect it to work one way, and when it doesn't they claim it's "broken" even though it's working as designed. There are a lot of threads on the subject.
I have it installed and I'm happy with it. Since you already said you need it, it seems like a no-brainer to me.
LOL i guess i did answer my own question. im waiting for my dealer to call back. I always to to get everything i want on something when i buy it. but this was new to me since i was looking at a different model and decieded it was to big for my need(RIGHT NOW).
   / Is it worth it or not? #6
I also wanted the three point hitch and the mid mount mower to operate separately from one another, so I went with the independent lift on my 2520. If you're looking for further support, I'm glad I went that direction :).
   / Is it worth it or not? #7
The independent lift kit is worth it but if you have the mechanical lift you only need the hydraulic kit. The other parts all work fine
   / Is it worth it or not? #8
I love my independent lift, it works well. No problems.
   / Is it worth it or not? #10
In my opinion, very few things from JD are worth every penny spent. BUT after I write the check and start using the JD item I sure am glad JD had one for me. And I will buy another at a later date! Oh, and I do have the independit lift on my 2305 and like it!
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2012 Dodge Ram 5500 Chipper Truck (A52377)
2012 Dodge Ram...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
