Is it time for a gasoline engine tractor?
   / Is it time for a gasoline engine tractor? #161
Typical use of CUT tractors is light duty . Even if it was medium or heavy duty so what . Rare is the CUT that is used more than 200hrs a year.
There is no definition of "light duty" as it relates to CUTs, so you're just making up a term with no meaning.
It's not how many hours per year and it's not that they sometimes run at low power settings. It's that they are rated to run at rated power indefinitely.
   / Is it time for a gasoline engine tractor? #162
Why do you insist on repeating things that are wrong? The national average price for regular unleaded and diesel are within a penny or two of one another, and have been that way for a year.
Crude price isn't the only factor in the price of fuel, and a rise in crude price alone won't make diesel instantly more expensive than unleaded. Diesel refineries had to repay billions in upgrades to comply with ULSD standards....that's paid off. Demand for diesel has been at unprecedented rates. Other countries are starting to refine diesel, and that will increase worldwide supply, which will keep the price low.
In short, pretty much everything other than your personal opinion points to diesel continuing to be similar priced to unleaded, and lower in many places. This station isn't losing money, and I'm pretty sure they don't have a sweetheart deal on the price of diesel:
Probably becuase some people have conveniently forgotten diesel being higher priced than gasoline from 2006 to 2015. How does the past year with low crude prices and diesel over production makeup for the past 9 years. ULSD and Tier V emissions are not going away.
Why are some people so offended with the notion there is a niche market for gas engines because tier IV and Tier V has made a small diesel in light duty applications less practical?
   / Is it time for a gasoline engine tractor? #163
Gas engines in tractors manufactured up to the mid 1970's and LP or Natural Gas engines to this day operate continuous full power and full rated rpms .
A CUT does not get used with as high of a duty cycle as Big Time Operator chisel ploughing 18hrs a day for two weeks. CUT spend thier time in a lighter duty cycle with short duty , start, stop operation that does not fully heat up the engine and exhaust treatment system.
   / Is it time for a gasoline engine tractor? #164
Because 2006 to 2015 is history, and there were specific factors during those years that cause the price of diesel to be higher. Those factors are gone and diesel is back to being less expensive than gasoline like it has been historically.
Your 9 years of high prices don't discount nearly 100 years of lower prices for diesel.
It's actually simple, but you won't admit the facts because they disprove your theory. Diesel producers have paid off the billions of dollars in upgrades required to make ULSD. Global demand has lowered. Crude prices have recovered from their artificially high levels in the past few years. Global supply is increasing as more countries start refining it locally. All of those are facts you can't change.
There is no Tier V. It's possible that if Europe enacts new standards in 2019, and the EPA might follow along and create a Tier V, but the manufacturers have already looked at the proposed European changes and found they already have solutions. The biggest change would be that engines under 24hp would be subject to the new rules, and a few engines that can get away without a DPF now will require one. That's about it....essentially a minor change with solutions already in place.
I'm not offended with the notion of a gas engine tractor, I'm offended by people making false statements time and again to support an argument that has no merit.
Manufacturers aren't making a gas engine CUT because it doesn't make sense for them to do so. They know their market a lot better than you do, and they have determined they can't sell enough of them to make any money on the idea. If they thought they could make more money going that direction, they would have already done so.
   / Is it time for a gasoline engine tractor? #165
That has noting to do with diesel CUTs. Nobody said a gas engine couldn't run at rated power continuously.
You simply don't understand duty cycle.
Lots of CUTs get run for hours on end at PTO speed....every time their owner brush hogs, tills, plows snow, etc. Certainly most spend some time at low power settings, but that doesn't change the fact that they are often run at PTO or rated speed for extended periods of time, and are capable of doing so indefinitely.
If the exhaust system isn't heated up as fully, or as long as required, all it means is a more frequent regen cycle....not exactly the end of the world.
   / Is it time for a gasoline engine tractor? #166
Oh, rider for sure. ;) I don't feel up to push mowing anymore. :)
I think you are missing what I said. there are plenty of GAS tractors that were running less HP engines than many rider lawnmowers are now.. if the small engine in a lawnmower doesn't have to meet an emission standard, why would it need to meet the standard in a tractor application? My current 12.5 hp rider mower is MORE hp than a few of my cultivating tractors.. think about it...
I disagree with your disagremment on gasser lie expectancy. ;)
looking at tractors and cars.. which, given is not straight apples to apples .. Look at gas cars from 70's 100k and the car was ready to be a toaster.
I think much of it is design and materials. Throw away engine designs coupled with alumin alloys, and non peak rated hp output put lots of stress on engines made smaller... that wore out and were junked instead of rebuilt.. vs a heavier beefier design meant to have liners punched out, bearings rolled in and crank polished and rings replaced then ready to go another couple decades. IE.. their constant load design was reflected in their materials. So.. 30's-60's were robust... 70-80's got puny.. now here we are with gas engines that don't need tune ups till past 100k.
I'd deffinately call that a bell. high, low, high...
OK, I wasn't thinking quite as small as you were. Farmall Cubs and so on was smaller than I was thinking, I was more in the 30 - 70 hp range. Those small engines wouldn't be exempt from emissions, they just have a little looser standards they have to meet. While the 70HP machine would need a catalytic converter and other goodies to make emissions, the small engines can just play with the cam and lean the carb out a lot to get by.
Gasser life expectancy I wasn't including rebuilds. So in my mind even though the old machines had sleeves, you had to rebuild them quicker. As materials and machining progressed the rebuild times kept getting out there longer and longer. Where today to borrow your car analogy you have cars that can get 200K+ miles before a rebuild. So I just see it as a linear line.
Hey look at that, we have had a great discussion on the internet without a single name, derogatory comment or any other disparaging remarks. I think we both win the internet. :drink::applause:
   / Is it time for a gasoline engine tractor? #167
OK, I wasn't thinking quite as small as you were. Farmall Cubs and so on was smaller than I was thinking,:
I've mowed plenty of acres with a cub and belly mower. they have less hp than my rider mower. :)
Gasser life expectancy I wasn't including rebuilds. So in my mind even though the old machines had sleeves, you had to rebuild them quicker.:
The reason I did include rebuilds is because you say some aluminum parent block throw away engines that didn't lend to rebuilding.. thus artificially limiting the lifespan of the vehicle / machine.
As materials and machining progressed the rebuild times kept getting out there longer and longer. :
untill they went with the non rebuildable units.
Hey look at that, we have had a great discussion on the internet without a single name, derogatory comment or any other disparaging remarks. I think we both win the internet. :drink::applause:[/QUOTE]
Agreed! :)
   / Is it time for a gasoline engine tractor? #168
All the manufactures of ULSD all paid off the costs for the equipment to refine ULSD on the same day? As for that equipment being paid off and low cost. After 10years the ULSD refining equipment is becoming worn and antiquated which requires $$$ investment by the refiners .
   / Is it time for a gasoline engine tractor? #169
You clearly don't understand what a duty cycle is. CUT aren't cars or light trucks, or forklifts, or man lifts, and comparing them is pointless.
What CUT or SCUT manufacturer publishes a limit to the amount of time their machine can run at full rated power? None. Any diesel rated for continuous full power is NOT a light duty application.
Rated for full continuous power and the the Tier IV emission equipment would work much better that way. However Uncle Putz on his rural estate cleaning the drive way or pgetting the horse a bale of hay with his 100hr per year CUT is not using the tractor anywhere near rated power continuously .
   / Is it time for a gasoline engine tractor? #170
A friend says that once in motion, a rig doesn't use much fuel. So it's not the weight that figures into it so much at that point as wind and tire resistance. Just look at a train.
On the subject of new diesel technology, one of our farmers has a high dollar Fendt Tractor. He figures that thing has about a fifteen year life span before all the computers, sensors, cabling and connectors just become too old and expensive to maintain.
That, to me, is not very positive. Even his new JD bailer has a computer!
My cousin bought a new Fendt saying it was the best... I was thinking what happens down the road when parts are too expensive or not available.
I do have to say it is by far the nicest tractor I've ever seen... very capable, powerful, beautiful cab and drives well on the highway.
2013 Peterbilt 367 T/A A-Frame Gin Pole Truck (A55973)
2013 Peterbilt 367...
1449 (A57192)
1449 (A57192)
Yamaha (A55758)
Yamaha (A55758)
BUSH HOG 8 SHREDDER (A58214)
BUSH HOG 8...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2011 Audi Sedan (A56859)
2011 Audi Sedan...
