Buying Advice Is it possible to go too big?
   / Is it possible to go too big? #91
Several post about instructors / buddy/child, or what ever you wish to call it.
I had one installed in my CX but it's a BIG cab on that tractor. I believe the cost was $400.00 ?
Anyway. My grand kids only ride when they just want to ride the tractor. It has, and they must use the seat belt.
There is no riding when I'm working .
You can always do as I did..If you buy too small a tractor, you can always buy a larger one and keep the smaller one as well.
There was no reason for me to trade the MX and lose money, and it is the tractor I use the most. Except pulling a seed drill, or using a heavy disk.
It's also great to have two tractors when getting up hay. One stays in the hay field to load the trailer. The other stays at the barn to unload and stack hay .
   / Is it possible to go too big? #92
Like some of the others, I skipped a lot & I'm sure all of it was extremely helpful and based on real life experiences. Me, I bought used, thought 2wd would be adequate, nope, was useless unless I had something huge on the back or else it just sat there. Now with that huge weight, I lost maneuverability in the trails. So I went to a 4wd tractor, again used, much better suited for my needs. I had no problem selling the used tractor to buy a bulldozer, which suits my current needs. The 4wd tractor was 55 horsepower, which was great for mowing the fields but it was a little big for maintaining my 1400' driveway, just wasn't necessary. So my 2 cents, which is worth exactly that, buy a smaller sized used tractor with a Quick Attach loader & grapple to "learn" on, and only a couple must have implements, maybe that brush hog or a flail mower to keep some of the jungle at bay. & Lease the main pastures to a farmer for hay, that way you both benefit, cheaper for him to mow improved field than to buy and clear land. Get a 0 turn for the lawn around the house. Hire out driveway because getting all the pitching, drainage, & sub layers right is harder than it sounds. Spend time with the kids and let the land work for you so you don't have to spend the time on it. Then after the driveway is in, & you've had a lot of seat time, then think about where your used tractor was adequate, too much, or too small, then buy a new one accordingly. Just my opinion.
   / Is it possible to go too big? #93
Hello folks. Moving to a 58 acre property soon from the 'burbs (also escaping CA, but that is a different discussion) and am looking into getting my first tractor. About 28 acres of the land is previously farmed acreage that I want to keep knocked down and tamed by semi regular mowing/bush hogging. I have a full time job that is not farming and have no intention of farming the land myself, at least in the near future.
As Lineman said a 30-35 hp one smaller tractor would probably be less intimidating to start out but, with a lifetime of farm and highway construction experience I like the biggest I can afford and especially if you're buying used, bigger is cheaper. I did a little quik searching and calculating on new tractors. It came out with a 30 hp tractor at $833 per hp and a 100hp at 500 per hp. https://advanton.com/new-tractor-cost/
Even though I had a Ford 2n, an AC- B and Case 580 backhoe loader, after using 4wd tractors on 45 degree slopes on the job, I told my wife when I retired I was getting a used small 30 -35 hp 4wd for use around my 23 acres. She actually agreed as a lot of my place is very steep and also wet swampy areas. After looking at several small ones, the cheapest I found was a small Ford with a snowplow blade that was beat for $7500 and a little better 81 JD 750 for 8k with no equipment. Everything else was 12-20k.
I saw a couple 4wd tractors going up for auction and went to look at them. I happened to arrive as the truck driver was unloading two 100 hp 399 Massey Ferguson right of way mowers and got talking with him. He tipped me off me which one just had a new engine with less about 80 hours on it. Both had new tires, 8' bush hogs, 50 ton winches and full forestry skid plates , cages etc. The one without the new engine went up first and a dealer and I were the final 2 bidders and I let him have it. The good one was next and the dealer bid it up to the same as he paid for the first one and I bid the next $500 and got it. I pulled out my credit card and paid about the same as the lowest priced small tractors. Then I drove it the 10 miles home figuring out the Massey color scheme to repaint it, because i figured my wife was going to have some words about that ugly black thing. Much to my surprise when I pulled down the driveway my wife and son came out and both said, "that looks like it's right out of the Road Warrior and you're not touching that paint. That's how he got his name.
Although Max more than fills my needs, tractors seem to be the same as workshops, no matter how much room you have, you always wish it was bigger.
As far as kids on tractors, I put a kids car seat behind mine and my grandson rode everywhere strapped in from 3 yrs old. BUT--- safety is the # 1 concern and he was never allowed on or near any equipment unless someone was with him and given constant safety reminders, most important to never approach any vehicle/tractor etc. especially from the rear, until the operator sees you and ok's it
Smiley
   / Is it possible to go too big? #94
"Stay under 150" Seems like good advice for tractors and women!
Haha love that one. I did go over the 150 rule for a tractor but I had a specific use case for it and it works well. Love the Mad Max tractory ^^
I've lurked here a lot but never posted before, but this one seemed to need another perspective. Most of the posters did not read or pay attention the OPs points.
1. He has very little time. Get a big tractor, get the work done faster. I've dinked around plenty on little tractors, they beat you up on rough ground and take way longer to get the job done. Just try spreading rock or leveling something with a small tractor vs a big one. Huge difference.
2. Child riding on the tractor. Lots of dire warnings. OP is former service and an ER nurse and seems pretty capable of assessing and mitigating the risks.
3. Learning curve. I can say for a fact having run a lot of big and little equipment that if you have depth perception a big tractor is easier and safer to run.
4. Cabs. OP wants a cab for comfort and safety. Get a Stihl pole saw and have your wife drive you around in the back of the pickup and take down any branches that will hit the cab. First thing I did and I repeat the edges of my field and roads every second or third year. It's maintenance.
5. Leasing out the ground. OP stated that he didn't want someone farming the ground around his house which is half of it and is very understandable. Those telling him to rent it out didn't read his posts.
6. Road building. If OP can stabilize a gun shot wound which he probably has plenty of experience with, he can learn how to properly grade a road so it will drain. Pro tip: Always put down geotech fabric under your rock. Depending on your base soil you can use half the rock and it will last much longer. Watch youtubes, maybe hire some of it done so you can watch. People have been building good roads since at least Roman times. Not hard.
I know well how the crowd here leans towards little tractors, that's what this forum is about, but the OP was asking about bigger tractors. I didn't figure I'd earn a lot of love over my perspective, but it's a different one and perhaps useful to the OP.
OP, suggest posting your question in the Machinery forum at New Ag Talk and see what kind of answers you get. When I posted there about the 225 HP Steiger tractor I was considering buying, one poster suggested I get a rototiller for it and till the garden reaally fast. 🤣
   / Is it possible to go too big? #95
Clearly I'm no expert, but I've been seeing a lot of videos of gravel driveway maintenance that use box blades, land planes, and landscape rakes. For those suggesting other machines besides a normal tractor, can you run all of those items and if so what size?
Yes. For size search YouTube for Toolcat or skid steer land plane, box blade and landscape rakes.
Here is a video from npartist a TBN member using a 7' box blade on a 5600:
The Eterra 7' box grader:
This is the one I bought:
This looks like a gooder-un:
   / Is it possible to go too big? #96
The OP stated in his first post that he WAS interested in the possibility of leasing out some of his land for someone else to farm, most folks here gave an opinion on what they felt would work for the OP nothing says that what works for one would be what is needed for others, your case in particular 25 farmable acres and 110, 150 , and 200+ hp tractors would be overkill for some but apparently it works for you, which is good, but just maybe you should go back and read the OP's post a little better, because it appears you missed a little bit as well.
   / Is it possible to go too big? #97
Hello folks. Moving to a 58 acre property soon from the 'burbs (also escaping CA, but that is a different discussion) and am looking into getting my first tractor. About 28 acres of the land is previously farmed acreage that I want to keep knocked down and tamed by semi regular mowing/bush hogging. I have a full time job that is not farming and have no intention of farming the land myself, at least in the near future. Leasing some of the land to someone else to farm is something I want to look more in to. The rest of the land is very thick vegetation and trees. Solid wall of green type situation.
Besides the previously mentioned 28 acres of maintenance taming, over the next few years I want to potentially relocate, and certainly maintain, the gravel driveway into the property which is about 1500', create a gravel "road" to the more separated farm area for lessees to access that 15ish acres which will be at least another 1500', fell some timber and clear brush to make trails to the more wooded areas, potentially light grading for a future storage structure and swing set, and support of some heavier/specialized rented machinery for constructing a private shooting range with berm backstops in the back woods. Near the house I'd like to set up a sizable garden plot for the wife and kids to tool around in and some tree planting around the new driveway for future privacy.
My question is this: Should I start with a "learner size"? I've never owned or driven a tractor but from research I've seen that a fairly sizable machine would be ideal for my needs/wants. I've also gotten my heart set on a buddy seat so in a few years when I've learned to drive the thing and my very young children are a tiny bit older they can ride with dad. I think those moments will be priceless. I have no brand loyalty and I've yet to see how dealers around me treat their customers, which I've heard is a huge consideration. I've also got my heart set on a cab because frankly I think it will make chores like the mowing enjoyable instead of potential misery.
The machines I've been interested in thus far are the kubota m4d-071 and the tym 1104 and I'm mostly considering new instead of used. I'm slowly working my way though the other colors looking for other models of weight, power, and size to fit my needs but I've gotten a bit nervous about my lack of experience and piloting something this large and expensive without ever even sitting in a drivers seat. Any thoughts? Am I getting in over my head with machines this big? The terrain around my house is about as flat as a pancake which is at least in my favor and because I have a full time gig elsewhere, my off time, which I'm hoping a machine this size will save some of, is very valuable and more time I can spend with my young kids. Thanks for your help and looking forward to getting to know you all.
With that amount of ground I would recommend an agricultural tractor of about 70hp rather that the flimsy compacts as they are designed to work, have the stability to do it safely, more comfortable to drive, easier to mount and are easier to find implements for.
   / Is it possible to go too big? #99
Heck, I wasn't looking for a 105 hp tractor. I already had a 50 HP tractor. I was just looking for about a 75 hp tractor.
Since I wasn't buying new to stay away from emissions, I bought my 105 HP cheaper than I could buy used a 70 HP tractor. It was a no brainer for me !
   / Is it possible to go too big? #100
Kids and tractors are a bad mix. Kids are immortal, just ask them. As was mentioned, tractors are slow but inevitable - and to date, I have been able to destroy anything I have been able to drive over (on my 26 hp Kubota 2601), which so far has been just about everything. To date, I haven't hit or damaged anything (yet) or hurt myself or anyone else, but as they say in the stock market, past performance is no guarantee of future performance.
Sometimes adults have no sense about tractors either. I was unloading a 40' container (on a truck) using pallet forks, and someone walked between the tractor and the truck/container. He's an adult and should have known a LOT better, and he promptly and deservedly got yelled at right and proper. If my foot had slipped, he'd have been crippled, as a minimum. Ten minutes later HE DID IT AGAIN, and at that point I told him to either get and stay in the (bleeping) container (moving the pallets with a pallet jack) or GTF away and go have lunch or something . . .
I don't want anyone hanging around while the tractor is working. The bush hog throws debris, sometimes very hard, even the belly mower can launch projectiles. I'm really, really careful and try to keep my situational awareness at 100% (pilot training helps) but other people don't understand that tractors can be really dangerous to the unwary or just plain unlucky (and luck is not a strategy).
Basically, if you get careless or sloppy around tractors, you should decide in advance what bodily appendage you will miss the least.
Always have the ROPS cage up and locked, and always use your seat belt. Approach, mount and dismount the tractor as if it is a) alive, b) malevolent, and c) live with 440 volts (three phase). Don't be scared of it, but respect what it can do.
2wd vs 4wd - Someone taught me a trick - go in with 2wd, if you get stuck, you can use 4wd to get out. If you get REALLY stuck, lock the diff (lever on the floor on my Kubota) and that will do it. If you get REALLY REALLY stuck, sometimes using the FEL as a "jack" will free you. If that fails, yell for help.
Size matters, but what I've found is that a smaller tractor can do almost as much work as a larger tractor, but it is going to take longer, sometimes a lot longer. Fortunately, I have two neighbors with larger tractors (a Kubota 5000 series, and a big green thing with about 60 hp) and they enjoy using their "big iron" as much as I enjoy using my "pipsqueak".
Each one of us has three or four implements and attachments, and they are all different. Between us, we have a good selection so we almost always have something that will get the job done.
Don't be afraid of sharing your knowledge, either. One friend bought a stump grinder and connected it up. He showed up just a'rarin to go and I noticed that the grease fittings looked pretty dry - in fact they were rusty (brand new machine). We did the grease-gun trick and then I wondered aloud if there was any oil in the gearbox. Guess what - bone dry! Shipped that way, no tag, nothing in the manual, no heads-up. If we hadn't looked, the vendor would have had a warranty fight. A quart of SAE 90 fixed that issue.
Be careful. Think. Have a good time!
Best Regards,
Mike/Florida
2019 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A58017)
2019 FREIGHTLINER...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
JOHN BLUE 1000 GALLON NURSE TANK (A52708)
JOHN BLUE 1000...
2017 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2017 Elgin Broom...
WHEELBARROW & TOOLS (A58374)
WHEELBARROW &...
Toro San Pro Bunker Rake (A56857)
Toro San Pro...
