Snow Is it dangerous to operate 4110 with industerial tires in 12 in snow on hill?
   / Is it dangerous to operate 4110 with industerial tires in 12 in snow on hill? #11
Everything is relative... I wouldn't hesitate if you're going straight up and down the hill. Across the face is different even when you're not in snow. I'd go slow and let your gut tell you.
Box blade isn't the best implement for snow removal, but if it's what you have, use it.
Good luck
Mike
I hate to disagree with you but the only thing I use is the box blade and it works perfect whether going forward or in reverse for snow removal plus it adds extra weight when using the FEL. I even added a couple extra wings to the box blade to help with moving snow and dirt.
   / Is it dangerous to operate 4110 with industerial tires in 12 in snow on hill? #12
I also use a box blade with good success. The biggest pain is no side angle, so have to push straight, then swing off to the side.
I know it's a bit late, but something I try to be careful about when pushing or pulling snow or dirt, is not to get into an area or situation where you can't get back out :eek:
I'm not always successful at that :eek: The FEL helps, plus if you are really stuck and on reasonably level ground, raise the bucket about 3/4 and rapidly drop and raise it about a foot.
This rocks the tractor and has gotten me out of more than one problem. (Especially when only one front wheel spins).
I know that's hard on it, but at 4am and the middle of blizzard conditions and getting people out where no one else can get, you gotta do what you gotta do- can't get off and push!
Hope this helps next time!
2014 Dodge Grand Caravan Van (A50324)
2014 Dodge Grand...
2015 Chevrolet Silverado 2500HD (A52128)
2015 Chevrolet...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2009 CASE IH3406 - 6R36" CORN HEAD (A51243)
2009 CASE IH3406 -...
