Is it a 2000 or 3000
   / Is it a 2000 or 3000 #21
C7008 could be some kind of model code. "C" was used as a prefix for 3000, but that was first in 1968. I think it is clear that the tractor was assembled in 1966, and at that time the prefix was "3" for the 3000.
The raised letters on the manifold are casting information, as I understand it is a code for were and when the mold was made.
The Antwerp units are often hard to identify. The rear axle does not necessarily mean that it is a 3000. I believe the 2000 LCG, for example, had square axle. The Antwerp factory made all sorts of combinations. Stuart Gibbard writes this in "The Ford Tractor Story, Part Two":
"...at the Antwerp plant, which built several specialist machines and could, in fact, offer 1,000 different variations on the four basic 6X models."
However, I think that if you have the draft control spring for a 2000, then the tractor is very likely a 2000.
Have you checked the Serial Number on the engine? All engines were manufactured in Basildon, England, and I suppose the engines for Antwerp were stamped in Basildon in the same manner as all other engines.
Check the pictures I have attached. If the Engine Serial Number starts with an "L" or a "B" it is a 2000 engine. If it starts with an "N" or a "C", then it is a 3000 engine.
   / Is it a 2000 or 3000 #23
It is an Antwerp built tractor with European spec fenders and platforms. A 2000 will have an exposed draft control spring. A 3000 will have an enclosed draft control spring. Square axles are not a positive indication of a 3000.
   / Is it a 2000 or 3000 #24
Ah -can't see the draft spring from the pic's on 1st post - didn't know some 2000's were equipped with square axle tubes that is interesting.
Ok- Antwerp tractor it is.
   / Is it a 2000 or 3000 #25
Yeah, there’s no picture of the draft spring. I’m thinking (but not at all certain) that the 2000’s do not have a hydraulic flow control valve on the right side of the rear axle center section.
   / Is it a 2000 or 3000 #26
Hi all....
I have a Ford 2000 and I also couldn't read the numbers to determine the model.
I feel that it is a 2000 because it does not have a flow control knob under the right side of the driver's seat.
Take care,
John
   / Is it a 2000 or 3000 #27
according to the info off the injection pump.. its a 2000
158cuin.. manuf. from 64'-75'
32bhp
2013 JLG SkyTrak 6042 6,000lb 4x4 Rough Terrain Telehandler (A55851)
2013 JLG SkyTrak...
2015 Caterpillar 314E L CR (A53314)
2015 Caterpillar...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
UNUSED FUTURE VR39 39" HYD VIBRATORY ROLLER (A57193)
UNUSED FUTURE VR39...
