Is hydro fluid extremely clear??
/ Is hydro fluid extremely clear?? #1
beppington
Elite Member
of my
Here
I confess: While I paid my dealer to do my initial 50-hour service, I never checked the hydro fluid level myself until tonight ... 155 hours in :eek: aka 105 hours after the 50-hour service.
So, I was surprised when I pulled the transmission dipstick out & could hardly see anything :shocked: I looked closer & closer, & ... am I seeing a very thin, very clear film of hydro fluid on the dipstick? I can't tell, but it seems like it, maybe ... ?!?
So ... Is hydro fluid this clear? It seemed to fall within the hi & lo marks. Looks about like water ... maybe with a little oil mixed in?
/ Is hydro fluid extremely clear?? #2
Yes, it is clear looking. JD sells a red dye for less than $4 to make it more visible on the stick and in the sight glass.
MT3668 FLUID, HYDRAULIC OIL DYE ADD 3.91 USD
/ Is hydro fluid extremely clear?? #4
Yup it's like water...Clean the dipstick really well and use a perminant marker on the bottom of the dipstick..Much easier to read. The dispstick should be black or the fluid dyed...A silver dipstick and clear fluid is a bad combo.
OK, thanks - I feel better. Phew.
/ Is hydro fluid extremely clear?? #6
There was a thread on here at one time where a guy flamed his dipstick to make it easier to read, but I don't remember the details so I can't recommend it. I usually just run my thumbnail along the edge. This stuff is really clear.
/ Is hydro fluid extremely clear?? #7
If you use the Deere dye, it's about a drop per gallon to get visible results. If you were changing out 10 gallons, I'd even start with about 6 drops. Start small, and if you need more contrast do another drop per gallon or two. I use it on my JD 318 so I can see the hdyro fluid in the sight tube. I don't use it for better readings on dipsticks on other equipment. Under a bright light or sunlight you can see where it's wet and where it's dry. Even more so if you're naturally myopic. That's visually, not mentally :laughing:.
Pete
EDIT: And a click of the 'ol mouse towards kennyd for suggesting the dye and knowing the part number.
Land Pride RB3584 3-Pt Blade (A66408)
Land Pride RB3584...
2015 Freightliner (A64119)
2015 Freightliner...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
