Is frequent short term use harmful?
   / Is frequent short term use harmful? #1
CutTheHolesOut
Bolens G274
good morning all. I’ve found myself using my tractor pretty often but only for very short periods of time. It got me thinking that maybe it could be causing some sort of harm but I don’t really know. I’m basically using it to turn a compost pile. Lazy or not, my back isn’t what it used to be. Is there any downside to starting it up, using the loader for three or four scoops and shutting it back down besides the battery might need to be charged more often? I mean it’s maybe a total of 3 minutes of use. It’s a bolens g274 if that makes any difference. Thanks in advance
   / Is frequent short term use harmful? #2
Don't know for sure, but I would say "yes" it does cause some harm, as moisture in the engine when first started hasn't had any time to evaporate during use, especially over a long period of time.
If yours is a diesel, you should let it warm up for at least a couple of minutes to let the fluids circulate and warm up a little, as well as the hydraulics.
I would suggest a long duration use (20-30 min) once in a while to mitigate any condensation in the engine.
My 2¢.
   / Is frequent short term use harmful? #3
I don't know one way or the other. I'm sure you will get opinions either way. If we stop using a tractor to make our life easier, we are defeating the purpose of having one to begin with.
Dave
   / Is frequent short term use harmful? #4
Do you only use it for this purpose or do you use it for more heavy and longer use?
   / Is frequent short term use harmful? #5
"Short Trips" are generally harder on any vehicle, and I would avoid not getting the tractor up to temp and working on a regular basis. I save up a few jobs for the times I wouldn't be running my tractor for very long.
   / Is frequent short term use harmful? #7
agree w/above statements. in addition, with repeated short cold start use, i certainly would be changing the engine oil far more frequently than manu recommendation due to moisture build up, etc in the crankcase
diesels, once warmed up, are meant to work steady, & repeatedly putzing around w/cold starts doesn't do one any favors, regards
in general, i'd let the engine warm up 5 min (longer in cold weather) & work it at least 20-30 min
   / Is frequent short term use harmful? #8
If you have a temperature gauge, make sure it gets up to normal running temperature, before working it and shutting it off. To accomplish that, it wouldn,t hurt to give it a run up and down your driveway, before putting it to work.
   / Is frequent short term use harmful? #9
No matter what kind of job/project I have. I always run it long enough to have it up to temperature for at least a half hour. Like has been said - it will eliminate any water that might be in any of the different oils.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
DETROIT DIESEL ONE BOX (A55745)
DETROIT DIESEL ONE...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
