Is frequent short term use harmful?
   / Is frequent short term use harmful? #31
I do the same as kneedeep.
   / Is frequent short term use harmful? #32
Cuttheholesout… Look at it this way…. Everything in life is a compromise.
If you only run 3 minutes at a time, you might…..might… have a higher H2O level in your tractor oils. Enough to cause noticeable damage on a machine that will only rack up hundreds of hours in your lifetime at most, not thousands ? Only you can say.
You make no mention so far, of your climate, tractor storage situation, or oil change observations, or frequency.
We can only guess with our suggestions.
Burning diesel to simply heat your engine to evaporate estimated “bad” internal H2O to prevent guesstimated future engine problems has a cost to it, that you have to decide for yourself if it’s worth the negatives.
While you might evaporate some water, and you won’t have to manually charge your battery(positives) , you are paying for a lot more diesel fuel, more hours on your meter giving a probable lower resale, more run wear on the engine in general, especially the injectors, fuel filters, etc….
I imagine from the fuel saved only running 3 minutes, you could put that $$$ savings towards $$ more often oil changes , or oil analysis.
It’s up to you, what’s most important
This seems to be the most comprehensive answer, so I'll add nothing more except to say that I had the "little brother" to that tractor, a 15 horsepower built by Iseki. It was about bulletproof!
   / Is frequent short term use harmful? #33
I add 15-20 oz. of seafoam in fuel tank for injector health, biocide for the fuel tank and typically run engine around 1500 rpm.
Short run times is same effect as a vehicle that makes short trips in town, acids and condensation is #1 enemy of internals.
One suggested holding off until you have enough chores to have at least a half hour run time.
I agree that it would help engine health.
Not familiar with your model but doe it have a regen cycle?
If yes, then maybe further issues down the road from soot build up?
I'm asking out of ignorance but pose question to ponder if applicable.
   / Is frequent short term use harmful? #34
This is right up there with people who ask me how they should run and charge their laptop so it lasts the longest. The proper answer is use it, and keep it charged. If you don't use it in such a way to make your life as convenient as possible you become a slave to the device rather than the device being a slave to you as it should be.
Technically, yes, you can do certain things to make a battery last a little longer but it destroys the entire point of it being convenient and portable.
Same with your tractor. If it's just super convenient to let a few jobs stack up before you do them, great. If not, don't ever avoid doing a job because you are worried about the tractor. That defeats the entire purpose of owning it.
Maintenance and repair will be necessary over time no matter how you run it. So get lots of use out of it while you can.
LOT: Landscape Timbers, Hand Tools (A59076)
LOT: Landscape...
2016 DORSEY FC48 48FT FLATBED TRAILER (A58018)
2016 DORSEY FC48...
Self Leveling Rotary Laser (Survey Equipment & Grade Control) (New/Unused) (A59225)
Self Leveling...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
(NEW) SOUP KETTLE (A58374)
(NEW) SOUP KETTLE...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
