Is anyone else having lots of problems with an 1850?
   / Is anyone else having lots of problems with an 1850? #61
AltavistaLawn said:
10/25/06.
Well the saga continues. The Alternator is now burnt up. The PT will sut off after a few minutes.
We were able to get it on the trailer and home.
This machine will bankrupt me yet.
Tell us more , Which model and engine are you talking about. you said the alternator fried. Something had to caused that. The regulator could be defective, and shorted the alternator to ground and therefore killed the alternator. Is the regulator built in on your model, or does it have a separate regulator?
   / Is anyone else having lots of problems with an 1850? #62
Concur with JJ: Need more data.... shutting down after a few minutes sounds like the circuit breaker is tripping from some kind of excess current draw or a bad breaker instead of the alternator. See my other post on the fix for a dead internal alternator regulator. I have had to replace the circuit breaker on my 1430 - probably accelerated by my blasting everything with a pressure washer! It was pretty rusty inside. Check current draw thru the breaker with an ammeter and if high (close to or over the breaker rating) try to find the high draw - could be an intermittent short from a damaged wire and that could be harder to isolate (one way to find intermittent faults is to cut some fuses into separate circuits and see which one blows and then trace that one out)
Don
   / Is anyone else having lots of problems with an 1850? #63
As far as the alternator, every thing has a cause and effect. If the current alternator is to expensive to fix or replace, You do have some options. A Ford or GM alternator might work just as well if the bolt holes and pulleys are similar. 40, 60, or 100 amp alternators, probably less than $100 used or junk yard. The one wire alternators are simple. The regulator is built in. Run one wire from the alternator to battery, and of course , a good ground.
Well ,it broke down again, separate from the alternator, generator or whatever.
The stupid little box that regulates hydraulic pressure started pouring fluid AGAIN!
This is the fourth time within 400 hours this has happened. It leaked hydr fluid all over a driveway. We stopped early, trailered it home, and I pulled it down and replaced the seal in the plunger assmbly again...at least I was able to get the o-ring seal from NAPA.
I guess I'll have to pull it down and replace the o-ring every 50 hours with the filter.
-Unbelievable.
   / Is anyone else having lots of problems with an 1850? #65
-Unbelievable.
Because this is apparently not a common failure, based on posts here, I would suspect that there is a defect in the regulator housing or in the plunger assembly that is causing premature failure of the o-ring.
   / Is anyone else having lots of problems with an 1850? #66
That gizmo failed for me too -- not quite as spectacular in terms of oil flow, but seals blown. I think I'm sitting at about 150 hours on my 1850.
I forgot to mention..the whole assemble was replaced last time. At least they did warranty it, it was about $250.00 part if I remember right.
   / Is anyone else having lots of problems with an 1850? #68
That puts the failures in a different light. Perhaps PT got a bad batch of parts. Alternatively there could be a design defect that only affects the 1850 (assuming that there have not been a significant number of failures in other machines).
   / Is anyone else having lots of problems with an 1850? #69
Kind of a tangent:
I am not very handy and am (was) getting very close to the purchase of a 1430. What kind of shop work (time and price) might be involved in fixing some of these issues?
Thanks
   / Is anyone else having lots of problems with an 1850? #70
IrTxRx said:
Kind of a tangent:
Thanks
None of these issues take long to repair -- the seals problem we've just been talking about probably took a total of about 15-20 minutes of actual repair time.
But it took several days to diagnose (the symptom was "oil leaking", which had to get narrowed down to "oil leaking from gizmo on side of engine compartment" which then had to get narrowed down to "oil leaking from the end with the spring" during conversations with Terry -- each iteration required lots of cleaning of the engine compartment to get rid of the oil that was already there).
Then it took a few days for the seals kit to get here via UPS from PT.
Then it took a trip over to Big Bruce at the implement dealer where his monstro power hands got one of the O-rings on a piston.
If you took this problem to a good implement/hydraulic shop I imagine they would have charged you, I dunno, a couple-three hours? Plus the hassle of hauling it over and back.
On the bright side, I don't think of myself as terribly handy either. But this kind of thing I've learned I can handle myself -- partly relying on Terry over at PT for instructions (he's great at that) and partly relying on this gang for ideas. I'd have spent a lot of money on my 1850 if I'd had a shop do all the work I've had to do on it. So unless you just simply hate that kind of thing, I'd suggest learning how to do the routine service stuff yourself.
   / Is anyone else having lots of problems with an 1850? #71
I am now wondering if you and altavista experienced the same failure. My recollection of the failure you posted about--brought back today when you said you had to take it to someone to get the o-ring installed--was that your failure was in the hydraulic accumulator.
My understanding of the altavista failures (4 I think) is that they were in the draft control assembly.
   / Is anyone else having lots of problems with an 1850? #72
How many people out there have an 1850?
How many people with 1850s have had hydraulic failures?
How many people with 1805s have had alternator failures?
Let's try to get some numbers on this.
   / Is anyone else having lots of problems with an 1850? #73
I've got an 1850 -- hydraulic failures "yes", alternator failures "no", hours - 140
There must be something else wrong with it this time. After 30 minutes it started pouring fluid, again. I took the "pressure regulating" box loose and watched it.. I never could see any fluid coming from it, spent about an hour looking...never did find the leak. In th emean time the pressure is running too high, so I adjusted it as low as I could by the two nuts on the plunger, but that didn't help.
To get the last job finished, we put an expandable freeze plug in the access hole to keep it from killing grass on the customers lawn. We're shut down now for all of next week, so we're going to tear it down. We might have to pull the engine to get access to the mess of hoses at the front of th eengine compartment.
I called the local Bobcat dealer, they said they would let me trade it in for a Bobcat all wheel steer; but I'll probably loose too much money to do it.
I'm really stuck in a bad place with this machine.
   / Is anyone else having lots of problems with an 1850? #75
AV,
From what I can tell, PT's are generally quite reliable, even if only because they are so simple that there aren't many parts to fail. You shouldn't be having so many problems. I get the feeling we're all missing something here. I worked on cars for over 20 years, and every now and then there would be one with seemingly inexplicable troubles. Usually it turned out that there was some simple failure behind it all that was so basic that nobody thought to check it.
The overheating problem seems to be a design issue. I see two choices: Find a way to keep the chaff out of the oil cooler; or add more oil cooling capacity. I do not agree with the claims that an additional oil cooler won't work. A cooler that is designed for both the pressure and flow will not cause a problem. Anybody who makes blanket statements that you can't add a cooler simply doesn't know what they are talking about. Adding a larger oil cooler is exactly like putting a bigger radiator in your pickup. If it can handle the pressure without restricting the flow, it will cool more. It's not black magic. If you can find out the maximum pressure and flow rate for the lubricating system, there's a cooler that will work. A little web surfing should find plenty of heat exchanger manufacturers and distributors (Like maybe Rapid Cool) that will be delighted to tell you what model should work.
The hydraulic fluid leak history makes me suspect something like a blocked return circuit. Big leaks often happen because of pressure spikes. If the fluid can't get back to the tank, something has got to give. If something blocks the return flow for a fraction of a second, that incompressible hydraulic oil will find a weak spot to blow out. Finding that may be time consuming, but a pressure gauge and methodical persistence should find it.
Another thought occurs to me - you might have something like a pinhole in a hose that only leaks significantly when the pressures are maxxed out, such as when the steering is at full lock, or when trying to climb a really steep grade. You could clean everything, and then simulate those conditions while looking for a leak. Be very careful - high pressure hydraulic oil can really hurt you.
Good luck.
Gravy
   / Is anyone else having lots of problems with an 1850? #76
This is some advise that I offered earlier, but is very effective in finding hydraulic leaks. Go to NAPA, and ask for some leak detecting fluid for oil. Clean the whole machine/engine with detergents and a pressure washer. Run the machine. When you notice a leak, get a black light , and shine over every thing. You should see a greenish/yellow glow at the leak. It is usually 100% effective.
   / Is anyone else having lots of problems with an 1850? #77
I've heard nothing but good comments regarding those leak detector kits.
Gravy,
I think you're exactly right.
JJ,
Yes, I failed to post it, but I am going to add dye to the hydraulic oil, after we get it cleaned out.
Looks like a very nice day today (temps near 70) to go get dirty.
   / Is anyone else having lots of problems with an 1850? #79
Gravy said:
AV,
Gravy
I don't remember anyone making a blanket statement that a supplemental oil cooler won't work. I've considered it pretty carefully, however, and I don't think it's a practical solution. First, plumbing it into the system would take some careful thought. Maybe an adapter at the filter would work, but it would be important to know the flow rate there. More difficult would be location of the cooler so it got adequate air flow - and didn't itself clog with chaff.
So far for me, it is clear that the system has adequate cooling when the air is clean, so that's the focus. Sedgewood's filter has been a pretty simple and effective cure, as has mine, so please modify the statement to: "a supplemental oil cooler may work, but probably isn't the easiest or best choice.":)
AV Lawn: any more intelligence on the charging issue? I hope it turned out to be a bad connection. I don't have any suggestions on the hydraulics. I've not had your problem.
Best of luck, and have a good holiday.
Thanks Charley.
Gravy was prob. commenting on my post where I posted I was told by the Duetz guys here (in Roanoke) that an aux. cooler wouldn't work, 'cause of oil pressure. (??)
I was told by them the correct brush kit will be shipped out by Deutz the first week of january, so the charging isn't fixed yet either.
After two hours of pressure washing today, I see yet another design flaw. I do not understand why PT didn't make the belly pan removable (like most equip., bull dozers, etc.) for cleaning and access.
Its going to be warm tomorrow too, so I'll work on it some then also.
Thanks for the posts, and hope everyone has a Merry Christmas.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2020 Chevrolet Silverado 1500 Pickup Truck (A59230)
2020 Chevrolet...
2017 GENIE S-45 TELESCOPIC BOOM LIFT (A60429)
2017 GENIE S-45...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
