Is A Stump Bucket Grapple A Capable Brush Handler?
   / Is A Stump Bucket Grapple A Capable Brush Handler? #1
TYM 474C
Hey y'all. I'm getting my list of must have attachments together and I'm trying to not have a stump bucket and a grapple. My place is a fire managed pine stand so there is less brush and more stumps but obviously still some brush. The question is, am I asking too much of a stump bucket grapple to clear and stack brush on the slash pile?
Thanks in advance.
   / Is A Stump Bucket Grapple A Capable Brush Handler? #2
I’m sure it would pick up a dead fall tree trunk fine but brush tends to get broken up in a lot of pieces. It’s going to be junk for raking up and moving little pieces.
Yeah, I was afraid of that. I use and landscape rake to break up duff and clean up worked areas but that would be an extra step.
   / Is A Stump Bucket Grapple A Capable Brush Handler? #4
How about this? stump bucket with grapple - Image Search
   / Is A Stump Bucket Grapple A Capable Brush Handler? #6
Xfaxman - are those stump bucket grapples designed for subcompact tractors or a unit like your Bobcat V417? Those might put a healthy strain on the subcompact FEL and hydraulics. Just asking.....
   / Is A Stump Bucket Grapple A Capable Brush Handler? #7
I find my root rake is handy when used as a dozer to push libs into a pile and grab the whole pile in one shot. Stump buckets are narrow and would be better at grabbing onsies-twosies i.e. grab "a" log or grap "a" root ball. A root bucket grapple wouldn't work for me and what I do.
FYI I have a set of powered forks. I can pick multiple root balls and larger roots than I can with my root rake. A thumb on these forks would be handy for grabbing piles of logs.
   / Is A Stump Bucket Grapple A Capable Brush Handler? #8
My Land Pride grapple is called - rock and root. In all my years out here - 40+ - I've only had two root balls. Trees that died and the wind pushed them over. I cut the trunks into appropriate size chunks and moved them to my burn pile. I left the root balls where they were. I occasionally have to fall dead trees - pine bark beetle. I cut them down - cut the trunk to size - move to my burn pile. I leave the stump right where it was. These are all out - well beyond my yard. Mother Nature will take care of the stumps.
   / Is A Stump Bucket Grapple A Capable Brush Handler? #10
23018 (A55758)
23018 (A55758)
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
