Is a ratchet rake redundant to a grapple?
   / Is a ratchet rake redundant to a grapple? #1
missesalot
Brockport NY
tc45d
Hey all, seasons greetings!
I have a 45hp tractor with a backhoe, FEL and bucket, and a grapple. I do a lot of brush clearing. I'm considering a ratchet rake for light weight grading of lawn areas, as well as stone driveway, in addition to its purported capabilities around brush grubbing etc. My question is, will a ratchet rake end up being very redundant to the capabilities I have in the grapple? The grapple I have is pictured here.
   / Is a ratchet rake redundant to a grapple? #2
I don't have a ratchet rake. I DO use my grapple to back drag as jumpin does. I have to keep my eye on the ball when doing this. My grapple is quite heavy - 800 pounds - tends to dig in if I'm not on the ball.
   / Is a ratchet rake redundant to a grapple? #3
I have done some land clearing of tree tops and small trees. I used a grapple and also a mini ex. If I didnt have to drag the brush far I would just use the mini ex.
Either way a landscape rake followed by a chain harrow worked really well for getting something decently flat that a normal residential lawn mower can mow.
My landscape rake has every other tooth removed and after useing it like this il never put the other half back in.
   / Is a ratchet rake redundant to a grapple? #4
I did the same thing with my landscape rake, using it for the exact same purpose.
   / Is a ratchet rake redundant to a grapple? #5
No
   / Is a ratchet rake redundant to a grapple? #6
I use my ratchet rake for ditch cleaning, gettin leaves and rocks out. Good tool for that issue.
I ended up buying a Ratchet Rake following the responses here. I was confident that it would be great, but after using it for the first time this afternoon I can say it’s significantly better than I thought it would be.
   / Is a ratchet rake redundant to a grapple? #8
I plan to dig my ratchet rake out of the corner of the barn and see how well it works on a rear blade. I hate the fact that with it on the bucket, you can't pick up dirt or debris.
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
INOP/NON-RUNNING 1999 Isuzu NPR-HD Cab and Chassis Truck, VIN # 4KLC4B1R5XJ001370 (A57453)
INOP/NON-RUNNING...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2015 Chevrolet Express 2500 Passenger Van (A56858)
2015 Chevrolet...
MMS SDLOOL Remote Control Mower (A57149)
MMS SDLOOL Remote...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
