Is a ratchet rake redundant to a grapple?
   / Is a ratchet rake redundant to a grapple? #1
missesalot
Brockport NY
tc45d
Hey all, seasons greetings!
I have a 45hp tractor with a backhoe, FEL and bucket, and a grapple. I do a lot of brush clearing. I'm considering a ratchet rake for light weight grading of lawn areas, as well as stone driveway, in addition to its purported capabilities around brush grubbing etc. My question is, will a ratchet rake end up being very redundant to the capabilities I have in the grapple? The grapple I have is pictured here.
   / Is a ratchet rake redundant to a grapple? #2
I don't have a ratchet rake. I DO use my grapple to back drag as jumpin does. I have to keep my eye on the ball when doing this. My grapple is quite heavy - 800 pounds - tends to dig in if I'm not on the ball.
   / Is a ratchet rake redundant to a grapple? #3
I have done some land clearing of tree tops and small trees. I used a grapple and also a mini ex. If I didnt have to drag the brush far I would just use the mini ex.
Either way a landscape rake followed by a chain harrow worked really well for getting something decently flat that a normal residential lawn mower can mow.
My landscape rake has every other tooth removed and after useing it like this il never put the other half back in.
   / Is a ratchet rake redundant to a grapple? #4
I did the same thing with my landscape rake, using it for the exact same purpose.
   / Is a ratchet rake redundant to a grapple? #5
No
   / Is a ratchet rake redundant to a grapple? #6
I use my ratchet rake for ditch cleaning, gettin leaves and rocks out. Good tool for that issue.
I ended up buying a Ratchet Rake following the responses here. I was confident that it would be great, but after using it for the first time this afternoon I can say it’s significantly better than I thought it would be.
   / Is a ratchet rake redundant to a grapple? #8
I plan to dig my ratchet rake out of the corner of the barn and see how well it works on a rear blade. I hate the fact that with it on the bucket, you can't pick up dirt or debris.
New Holland T2420 (A53317)
New Holland T2420...
2017 Volvo VNL S/A Sleeper Cab Flatbed Hauler Truck (A56858)
2017 Volvo VNL S/A...
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
