Is 20 ton enough?
/ Is 20 ton enough? #41
big deano,
Thanks for the link. Will study up on it.
dadster4
That's how I usually bend most things in the shop. It is also how I did the 1/4" test piece. The press was a passing thought, but I need to upgrade my torch set. The little MC set has seen it's better days. Thinking of a cheap set from Harbor Freight, cause I only use it for projects like this so welding isn't critical. Unless someone knows they are dangerous or something.
you can get a lp cutting tip for nearly any brand of torch and save a bunch of cash not having to lease a acetylene tank. It takes just a bit longer to preheat and doesn't soot.
/ Is 20 ton enough?
I think I will end up with a new set of torches. The whole set is getting pretty worn out. It is from the late 70's and was used hard those first 4 years.
/ Is 20 ton enough? #43
Howdy, first off, the HF 20 ton press is a bit weak, the biggest problem being the cast plates that come with it. I broke one in half bending metal with mine and also broke my foot. I used the remaining plate to make a nice pattern and cut some new base plates out of 3/4 plate. One other way you can make the bend you want would be cut the outside of the bend you want to make 1/2 way through with a cut off wheel or hacksaw, make your bend and weld the cut closed. Once youve split your angle you have lost the strength of the section of angle anyway and that way would be stonger than a piece of flat bar welded in
Or you can buy a couple of beautiful plates from swagoffroad.com. They are expensive but beautiful.
/ Is 20 ton enough? #44
3/4" is kind of thin for a 20 ton press. I got a piece of steel that's 1 1/8" think 4" by 40" that I cut up into 8" sections.
2022 EZ-GO ELITE...
2020 FREIGHTLINER M2 106 4X2 S/A 26FT TARP SIDE BOX TRUCK (A59912)
2020 FREIGHTLINER...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
Shuttle Bus (A61573)
NEW HOLLAND TRACTOR (A64280)
NEW HOLLAND...
7ft Fork Extensions (A61572)
7ft Fork...
