Is 12 year old K-1 kerosene ok in barn heater?
   / Is 12 year old K-1 kerosene ok in barn heater? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I discovered some 5 gallons containers I filled with K-1 kerosene about 12 years ago. I used good, clean containers that were filled full and stored in a good environment off the floor. Any problem using in my salamander type barn heaters?
   / Is 12 year old K-1 kerosene ok in barn heater? #2
If it tastes more oily than acidic you should be good to go. :licking:
   / Is 12 year old K-1 kerosene ok in barn heater? #3
After twelve years stored like that it should burn. A salamander isn't exactly a high tech device. You should be fine.
Thank you. I'll go for it when it's colder out and update. I thinkI have 25 gallons.
   / Is 12 year old K-1 kerosene ok in barn heater? #5
I have some from Y2K and older, that I would have no hesitation in using.
   / Is 12 year old K-1 kerosene ok in barn heater? #6
I wont use anything over 1 year old,--cept for brushpile lighting. Good way to mess up burners. ---IF you have the big pot type units--then it would be o.k. but NOT the newer pump/filter/nozzle kind.
   / Is 12 year old K-1 kerosene ok in barn heater? #7
I use a Monitor heater as backup in the house. K-1 stored in a 250 gal tank. Have not filled the tank in 7+ years, no problems. Kerosene and diesel don't seem to go bad unless water or algae gets in it.
   / Is 12 year old K-1 kerosene ok in barn heater? #8
in 1972 i put 23000 gals of k 1 in the ground for the company. it cost 13 cents per gallon. when the building was closed about 1993 when i left the took out the generator and sucked out some 21000 gallons that was left to put in another building.
   / Is 12 year old K-1 kerosene ok in barn heater? #9
Me too......got a couple of 55 gal drums of it, I'd have no hesitation about using.
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
R-134A Manifold Gauge and Hose Set (A55218)
R-134A Manifold...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
