Is 12 year old K-1 kerosene ok in barn heater?
   / Is 12 year old K-1 kerosene ok in barn heater? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I discovered some 5 gallons containers I filled with K-1 kerosene about 12 years ago. I used good, clean containers that were filled full and stored in a good environment off the floor. Any problem using in my salamander type barn heaters?
   / Is 12 year old K-1 kerosene ok in barn heater? #2
If it tastes more oily than acidic you should be good to go. :licking:
   / Is 12 year old K-1 kerosene ok in barn heater? #3
After twelve years stored like that it should burn. A salamander isn't exactly a high tech device. You should be fine.
Thank you. I'll go for it when it's colder out and update. I thinkI have 25 gallons.
   / Is 12 year old K-1 kerosene ok in barn heater? #5
I have some from Y2K and older, that I would have no hesitation in using.
   / Is 12 year old K-1 kerosene ok in barn heater? #6
I wont use anything over 1 year old,--cept for brushpile lighting. Good way to mess up burners. ---IF you have the big pot type units--then it would be o.k. but NOT the newer pump/filter/nozzle kind.
   / Is 12 year old K-1 kerosene ok in barn heater? #7
I use a Monitor heater as backup in the house. K-1 stored in a 250 gal tank. Have not filled the tank in 7+ years, no problems. Kerosene and diesel don't seem to go bad unless water or algae gets in it.
   / Is 12 year old K-1 kerosene ok in barn heater? #8
in 1972 i put 23000 gals of k 1 in the ground for the company. it cost 13 cents per gallon. when the building was closed about 1993 when i left the took out the generator and sucked out some 21000 gallons that was left to put in another building.
   / Is 12 year old K-1 kerosene ok in barn heater? #9
Me too......got a couple of 55 gal drums of it, I'd have no hesitation about using.
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2008 JOHN DEERE 672D MOTOR GRADER (A52705)
2008 JOHN DEERE...
