Is 10% Ethanol a problem, can I do anything about it?
   / Is 10% Ethanol a problem, can I do anything about it? #21
I have done a lot of reading the last few days on the issue. Personally, I will be looking for non. blended fuel in the future for my small engines. I would like opinions on which is better to run the engine dry or run stabilized fuel through the system? I know that seals tend to dry and may crack or rot when exposed to air.
Here's the some conclusions from what I have read:
Small engines makers are behind the curve in adapting to alcohol blended fuels.
Alcohol blends have shorter shelf life due to attraction of moisture
Alcohol blends cause engines to run hotter, see results from study on last link
Alcohol causes erosion and corrosion in some plastics rubbers and metals
Alcohol has more solvent properties and using in fuel systems that already have deposits will loosen and dissolve them, which may clog jets, valves and filters.
Here's some links regarding the issue:
Common ethanol fuel mixtures - Wikipedia, the free encyclopedia
Ethanol may cause damage to small engines - WQAD
NPR: Ethanol éŠ*ills Small Engines? | PowerET Blog | The Official Blog of Power Equipment Trade
http://pods.dasnr.okstate.edu/docushare/dsweb/Get/Document-6015/BAE-1746pod.pdf
http://www.afdc.energy.gov/afdc/pdfs/int_blends_rpt_1.pdf
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2018 Toro Groundsmaster 4000D Batwing Commercial Rotary Mower (A59228)
2018 Toro...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
2015 Forest River Rockwood Freedom Pop Up Trailer (A59231)
2015 Forest River...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
