Investigating other options on trailer build
   / Investigating other options on trailer build #1
dilligaf241
DeFuniak Springs, FL
Kubota L3400 w/ LA524 loader
Hey again everyone. I am doing a new frame and reusing the axles for my Kubota Hauler. So wanted input on what I would need as far as steel and see if maybe someone has an old set of plans I can look at. Not trying to be cheap, just don't want to buy a set if I decide to not go this route. Also all the bumper pull plans I have found for deck over trailer are shorter than what I need. I have to have at least 21' of bed area. My tractor with the loader and a bush hog is right at 20'. Thanks in advance for any advice.
   / Investigating other options on trailer build #2
Why not just go take a few photos of a manufacturers trailer with some measurement of the channel steel size including flange and lip thickness. If building I would upgrade to the next heavier size anyway, plus put more cross bracing in
   / Investigating other options on trailer build #3
I would agree with copying a design but why waste money and hauling capacity with oversize steel? A company that is in business to produce trailers has the engineering background (hopefully) to size things properly.
   / Investigating other options on trailer build #4
Adding to a plan shouldn't be too big of a deal but you will have to change your axle placement.
2015 Dodge Dart Sedan (A51694)
2015 Dodge Dart...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53473)
2019 Ford F550...
