Investigating other options on trailer build
   / Investigating other options on trailer build #1
dilligaf241
DeFuniak Springs, FL
Kubota L3400 w/ LA524 loader
Hey again everyone. I am doing a new frame and reusing the axles for my Kubota Hauler. So wanted input on what I would need as far as steel and see if maybe someone has an old set of plans I can look at. Not trying to be cheap, just don't want to buy a set if I decide to not go this route. Also all the bumper pull plans I have found for deck over trailer are shorter than what I need. I have to have at least 21' of bed area. My tractor with the loader and a bush hog is right at 20'. Thanks in advance for any advice.
   / Investigating other options on trailer build #2
Why not just go take a few photos of a manufacturers trailer with some measurement of the channel steel size including flange and lip thickness. If building I would upgrade to the next heavier size anyway, plus put more cross bracing in
   / Investigating other options on trailer build #3
I would agree with copying a design but why waste money and hauling capacity with oversize steel? A company that is in business to produce trailers has the engineering background (hopefully) to size things properly.
   / Investigating other options on trailer build #4
Adding to a plan shouldn't be too big of a deal but you will have to change your axle placement.
FAKE (A52472)
FAKE (A52472)
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2022 COSEN INTERNATIONAL INC V-1822 BAND SAW (A51248)
2022 COSEN...
