Invention is the mother of necessity
   / Invention is the mother of necessity #1
orezok
Elite Member
Mojave Desert, CA
Kubota B7800
The cutting edge on my back blade has worn out. I flipped it once and it's worn out again. I looked for a new edge, but I couldn't find one that had the same 12" bolt spacing as mine. The closest tractor place to me is about 60 miles away, so I wasn't willing to make the drive. I did find some online, but with shipping the cost would be well over $200.
I did some more research and found that Bobcat bucket cutting edges are common, but are designed to be welded on. I decided to take the risk and drill matching holes myself. The 72" blade cost $71 at Amazon with free shipping.
Now this edge is made from 1055 steel which is harder than the hinges of HE**. Again some research which indicated that cobalt drill bits would probably cut it but 5/8" ones are again pretty costly. I finally found out that carbide masonry bits work great on steel if resharpened to a drill bit configuration. Each hole took 5 to 10 minutes of drilling at 290 RPM and moderate to heavy pressure. The bits required resharpening about half way through each hole and I used pipe cutting oil as a lubricant.
Below are progress photos and the final product.
   / Invention is the mother of necessity #2
Believe it or not, I use wood hole saw bits on steel and they work like a charm.. Your blade should stay in good shape for years..
   / Invention is the mother of necessity #3
Dormer makes excellent drills and I have drilled thick truck leaf springs with proper cutting oil more than a few times.
   / Invention is the mother of necessity #4
What brand?
   / Invention is the mother of necessity #5
Wow.. I'll bet that was tedious.!! Nice job..
   / Invention is the mother of necessity #6
Nice job and coins still in your pocket. :thumbsup:
   / Invention is the mother of necessity #8
Nice job, how long did it take to resharpen to a drill bit configuration? I've never even sharpened a regular drill bit.
   / Invention is the mother of necessity #9
I really do like that solution. Bits are cutting well. I had to do the same on my Land Pride RB3596 after about 20 years of use. I was able to obtain two brand new road grader blades. Used one on the RB3596 and the second one is waiting in the work shop - it will go on the Rhino 950 - if ever needed.
I dam near gave up on the entire project though - both blades are 14 foot and had to be cut down to 8 foot. I didn't think my hack saw was EVER going to get thru those two cuts. I don't have a cutting torch either. However, persistence and several hacksaw blades finally paid off.
Drilling the holes for attachment went a lot better. I have good drill bits and I did purchase Drill DR to resharpen - often.
I have no idea what type steel they are made out of - but after 15 years of use - the blade on the RB3596 is just beginning to show wear on the outboard edges.
   / Invention is the mother of necessity #10
For the question about hole saw brand...Lennox makes a good bi-metal saw that works well in steel. I'd use a 1.875" one to cope for the uprights when building big gates.
KUBOTA M6800 TRACTOR (A54756)
KUBOTA M6800...
Giyi 44" Mini Grapple (A53316)
Giyi 44" Mini...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND68FDGH1824 (A54865)
2015 Freightliner...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A55787)
2025 68in Dual...
Estate Equipment Auction 9/27/2025
Estate Equipment...
2015 Ford F450 Stake Body Dump (A47477)
2015 Ford F450...
