Invention is the mother of necessity
   / Invention is the mother of necessity #11
Lennox is exactly the ones I buy..
   / Invention is the mother of necessity #12
:thumbsup:good job and wise money management all in the same project. Oh how I miss blacksmiths. When I was a youngster there were blacksmiths in every town and some in between. The last two around here closed up about 20 years ago. Their apporch is heat metal one or more times to certain stages,cool at certain rate between heats,work the metal then reverse the process to restore.
   / Invention is the mother of necessity #13
Looks like you did a great job on it! Would have nice to have had a plasma handy though - would have made quick work of the holes.
   / Invention is the mother of necessity #14
Well, they're a brazed on carbide. I have never tried to sharpen masonary drills. Seems like a lot of work. Bolted connections dont really need to be machined. A torch with a grinder touch up would have been my choice. You need to buy a cheap Victor set up and some tanks. Did you try to resharpen the originL edge?
Most cutting edges are T1 or AR400 or one of the other low alloy quench and tempered steels. Plain carbon 1055 would wear out pretty quickly. Victor makes a powder torch. It would need to be special ordered and needs acetylene.
I applaud your follow through. You are one tough dude.
   / Invention is the mother of necessity #15
Believe it or not, I use wood hole saw bits on steel and they work like a charm.. Your blade should stay in good shape for years..
I know this is an old post but for those in the know, when using a wood hole saw on metal, don't you need to use some kind of oil? I've heard transmission oil is a good cutting oil but is that true? Or some other oil.
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
Giyi Pile Hammer (A53316)
Giyi Pile Hammer...
2014 Ford F-150 Pickup Truck (A55788)
2014 Ford F-150...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55301)
2-Row Peanut...
2014 Bomag BW900-S50 (A47477)
2014 Bomag...
