Introducing... The Delta Hook Rapid Hitch System
   / Introducing... The Delta Hook Rapid Hitch System #1
Muhammad
Administrator
Moderator
San Diego, CA
None currently
Hello Everyone,
Just wanted to pass along a formal product announcement for the Delta Hook Rapid Hitch System. You may have seen mentions of this product in discussions, or have seen their ads here on TractorByNet.com.
Feel free to discuss this product in this thread, and of course check their website at Delta Hook Homepage for more information.
The manufacturer has provided us with this this informational video as well as the product description below.
<object height="355" width="425">
<embed src="http://www.youtube.com/v/EVDCx-dg1vg" type="application/x-shockwave-flash" wmode="transparent" height="355" width="425"></object>
The Delta Hook is a rapid quick hitch system designed to allow you to safely and easily change your tractor implements. A snap to install, the Delta Hook is simple and safe to use. Once the plates are attached, simply back towards the implement you want to hook up, stopping when the control plate meets the receiver plate. The lifting arms are then used to raise the control plate up and into the receiver plate, lifting the implement. The Delta Hook automatically aligns and locks into place. Changing implements used to take 25 minutes and 2 people. Now 1 person can perform the same task in an average time of 1.5 minutes!
Safe - Simple - Solid
Why not make your life easier today?
Category 1 or 2 Systems Available!
More information at: Delta Hook Homepage
   / Introducing... The Delta Hook Rapid Hitch System #2
Does anyone have any experience with this product? I'd be interested to see how it performs.
   / Introducing... The Delta Hook Rapid Hitch System #3
Just curious, Tigers1981, are you interested in buying one or are you interested in promoting the product?
John
   / Introducing... The Delta Hook Rapid Hitch System #4
This is from their web site, if you mutiply that by the number of implements you need to attach you are in to some serious money!
Catagory 1 Pricing
Category 1 Kit (20 to 60 HP)
$859 per kit
$289 Control Plate in-kit price
$285 Receiver Plate in-kit price
   / Introducing... The Delta Hook Rapid Hitch System #5
I called the company and the initial kit has the control plate and 2 receiver plates. I was confused by the pricing being so off between the kit and individual pieces. I like the ease of use this product offers, however for the price I am still leaning toward the Pat's easy change system. I only have to switch between the mower, cutter, box blade and rear blade.
   / Introducing... The Delta Hook Rapid Hitch System #6
Thanks for posting that. I was wondering as well. I like the idea. If the receiver were not so highly expensive I would buy the system for my wife. Shes using Pats. I just cant justify a couple $k to equip both tractors and all implements.
larry
   / Introducing... The Delta Hook Rapid Hitch System #7
There are several systems very similar to this out there. I've looked at them over the years but with over a dozen attachments the $$ just add up too fast.
Andy
   / Introducing... The Delta Hook Rapid Hitch System #8
Pretty pricey... I get by fine with Pat's Easy Change, a hydraulic top link and the PVC removable pipe extensions I made to the 3PH control so I can work it and the hydraulic top link from behind the tractor.
   / Introducing... The Delta Hook Rapid Hitch System #9
I get by just fine with the standard bare 3ph... and absolutely no worries about compatibility issues like with all the various "quick hitch" products.
25 minutes and 2 people to change implements? Gimme a break...:rolleyes:
   / Introducing... The Delta Hook Rapid Hitch System #10
Andy
Cost is the major problem with this type of hitch. If the expense wasn't so high, I would have had a set years ago. I have even known a couple of guys that had this type (but not this brand) and they work great.
2003 Komatsu WA250-3MC Articulated Wheel Loader (A55787)
2003 Komatsu...
2008 Walker Mudhog (A55787)
2008 Walker Mudhog...
2015 Ford F-250 Knapheide Service Truck (A55788)
2015 Ford F-250...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2015 Nissan Rogue SUV (A55758)
2015 Nissan Rogue...
UNUSED LANDHONOR LHR-SL2T3M CHAIN HOIST (A54757)
UNUSED LANDHONOR...
