Intimidating Drivers
/ Intimidating Drivers #142
I believe you have bad drivers in every type vehicle on the road. As far as electric autos, as long as they have a transmission they can keep 'em. When they design them like today's locomotives, I will be interested.
/ Intimidating Drivers #143
Volt. Volt is gas electric similar to locomotives.
S
/ Intimidating Drivers #144
S
Locomotives are entirely electric driven off of a generator that is driven by an internal combustion engine.
The volt is a plug in hybrid that runs off of the battery until it gets low, then the engine CAN kick in to directly power the vehicle, depending on depth of battery drain and power required to the drive wheels. Locomotive engines NEVER engage the drive wheels ever.
Chevrolet Volt - Wikipedia, the free encyclopedia
S
And you talk about government-sponsored vehicles, sheesh...... Government Motors is going to try and make that car profitable no matter how much it costs them.
/ Intimidating Drivers #146
Gas engine in volt is not connected to drive wheels it is pure gas electric after batteries are drained. I'm not advancing Volt but I understand how it works. It is not a true hybrid, only power to wheels is electric motor.
HS
/ Intimidating Drivers #147
2010 Volkswagen Polo BlueMotion Diesel - Quick Spin - Car and Driver
The batteries are not necessary for the mileage, and not worth the risk and added pollution and cost to manufacture. We just need to get the real cutting edge high mileage technologies into the country that the rest of the world enjoys.
HS.
Last thing we need is more tech.we need the EPA to buzz off and quit strangling our vehicles with regulations the rest of the world don't have to cope with.
/ Intimidating Drivers #148
Nice small car the VW polo TDi, 71mpg combined driving, pushing 100mpg on highway. I have seen them it looks just like a golf but just a little smaller, almost not noticeable side by side. High pressure diesel is clearly the way to go, hybrid and electric are inferior technology's.
HS
/ Intimidating Drivers #149
HS
You are incorrect. The gas engine can engage the drive train directly when needed to assist the electric motors.
/ Intimidating Drivers #150
Four Modes of Operation Let's walk through the four modes in which the 2011 Chevrolet Volt works.
Mode 1: Low-speed electric-only mode up to 70 mph. The main traction motor-generator is turning, but it can only go so fast. Here the ring gear is locked so it can't turn. The second motor-generator and the engine are disconnected and out of the picture. The main traction motor is left alone to drive the sun gear from battery power, which sets the planets in orbit. The orbit speed is sent out through the carrier and is proportional to vehicle speed.
Mode 2: High-speed electric-only mode up to top speed (100 mph). The engine remains dormant. Now the ring gear unlocks and is instead clutched to the second motor-generator, which is acting as a motor to set the ring in motion. With the sun already spinning, any rotation of the ring in the same direction will increase the overall orbit speed of the planets, which in turn increases vehicle speed beyond 70 mph.
Mode 3: Low-speed series hybrid mode up to 70 mph. Gasoline is now the base fuel that's propelling the Volt in series-hybrid fashion. The battery has run down as far as the control system will allow. The ring gear is unlatched from the second motor-generator and locked in place as it was in Mode 1, and the main traction motor once again is solely responsible for making the planets orbit. But the electricity to do that now comes from the gas engine, which has been clutched to the second motor-generator, now in generator mode.
Mode 4: High-speed series-parallel hybrid mode up to top speed. This is classic gasoline-powered series-parallel operation. You can't have both electric motors driving the car at high speed like we saw in Mode 2 because the battery is discharged, meaning that the second motor-generator must continue to be a generator driven by the engine. This is where the engine begins to directly drive the ring gear. The engine is already clutched to the second motor-generator, so a straight-through mechanical connection is established when the ring's motor-generator clutch is engaged. Compared to Mode 3, the engine works harder here because it is simultaneously driving the ring gear and the shaft of the generator. Getting the Terms Right GM points out that the different planetary layout used by the Toyota Prius Plug-In makes its engine come on in Mode 2. On the other hand, GM's Voltec system has three clutches, while the Prius HSD system has exactly zero.
GM also reminds us that the Volt's gasoline engine (premium fuel required, by the way) never directly drives the car without the help of an electric motor. That's true, even in Mode 4 where the sun is still being turned by the main traction motor. None of their gasoline engines can move them an inch without an electric motor applying torque to one of their planetary elements.
I will give this one to you, except its not a true transmission with a gas engine driving the wheels.
HS
Crown RM6025-45 Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2013 Nissan Juke (A59231)
2013 Nissan Juke...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
2025 GIYI SE61 61in Sweeper Skid Steer Attachment (A59228)
2025 GIYI SE61...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
