International 500 E Crawler Hydraulic Pump Front Pump Seal Keeps Leaking
   / International 500 E Crawler Hydraulic Pump Front Pump Seal Keeps Leaking #1
ARBAINES
Rockdale,Texas
International 500E
I have had the hydraulic pump rebuilt twice. The first time after I reinstalled it and filled with fluid and as soon as it started the front seal blew. Removed pump sent back to hydraulic shop after they found their problem reinstalled again and after running for 1.5 hours seal is leaking again. any ideas as to why it keeps leaking?.
   / International 500 E Crawler Hydraulic Pump Front Pump Seal Keeps Leaking #2
It is possible the shaft is worn.
They would surely have spotted shaft wear, but you never know. .
   / International 500 E Crawler Hydraulic Pump Front Pump Seal Keeps Leaking #3
How is this pump mounted and driven? Is it bolted solidly to a housing and driven by a gear or something similar inside?
I helped a neighbor diagnose a broken hydraulic pump drive shaft on a Steiger. The pump was driven by a tang on a shaft that fit into a gear in the transmission. The bearing holding the gear was very loose and within a short time had broken the shaft on the second hydraulic pump. You could have the same issue. That being that there is nothing wrong with the pump but the wrong could be in what drives the pump.
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53473)
JOHN DEERE ROW...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
1987 CASE IH 9150 TRACTOR (A53843)
1987 CASE IH 9150...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
